Old 04-15-2018, 02:22 PM   #1
Water Drain Plug
Hey All,
Do you all know where I can find the white rubber piece to the drain plugs? I noticed after de-winterizing that my hot water drain didn't have the rubber insert. You'll notice one of the plugs has one the other (hot water plug) doesn't. Where can I purchase one of these?
2004 Flagstaff 228 MAC - Retired
2015 Coachmen Clipper 17BH - Current
wheatbread is offline   Reply With Quote
Old 04-15-2018, 02:27 PM   #2
Any good hardware store or any of the big box stores should be able to fix you up.
Days Camped: '16=46 '17=30 '18=51 '19=53
Old 04-15-2018, 02:30 PM   #3
x2 bring the parts with you so you can match up and not guess
Kimber45 is offline   Reply With Quote
Old 04-15-2018, 02:31 PM   #4
So this is a common piece I can find at home depot? That would be helpful, what department would I find this in?
Old 04-15-2018, 02:32 PM   #5
fonzie's Avatar
Is the rubber seal still on the low point drain pipe?
Fonzie
Nights Camped:2012(36) 2013 (17) 2014 (18) 2015 (18) 2016 (36) 2017 (32) 2018 (42)
Old 04-15-2018, 02:34 PM   #6
No I checked, I don't know what happened to it.
Old 04-15-2018, 02:42 PM   #7
Just as confused as you
Scrapper's Avatar
I lost one of mine last spring when I de-winterized, had a 5-gal pail under the low point drains and forgot to retrieve the seal before I flushed out the AF. I taped it up with teflon plumbing tape.
Richard & Jill
Camping since 1989, seasonal since 2000
The Faster I Go, The Behinder I Get.
Old 04-15-2018, 02:43 PM   #8
Denver To Yuma In 90 Days
If I were to take a wild guess...the plumbing or garden departments would be a good place to start?
JohnD10 is offline   Reply With Quote
Old 04-15-2018, 03:06 PM   #9
Replace the caps wh valves then you wonít have to deal with it in the future - just open the valves to drain.
WY Husker Fan is offline   Reply With Quote
Old 04-15-2018, 03:07 PM   #10
Flybob's Avatar
As long as you are off buying parts, I would recommend you get 1/4 turn valves to install on the LPDs instead of the end caps. Makes draining much easier and no more lost washers
2015 Freedom Express 248RBS
TST Tire Monitors
Honda 2000I + Companion
2 100W solar panels
Old 04-15-2018, 03:09 PM   #11
Who Dares, Wins
doc73's Avatar
I installed quarter turn valves with hose bibs on the end. So now I have a hot and cold outside hose connection on the camper (can be used while hooked up or dry using the pump).
2015 ChevyHD D-Max
2018 Artic Wolf 315tbh8
doc73 is offline   Reply With Quote
Old 04-15-2018, 03:18 PM   #12
DavidBo's Avatar
I replaced my low point drain caps with these that I fabricated out of some 1/2 inch PEX and a couple if 1/4 turn valves. I had to remove the factory rubber seal (what you are missing) because the new threaded fittings came with one. You don't necessarily have to build up the valve assemblies, but you might get away with using just the rubber cone pulled from one of those fittings. I got everything at Home Depot.
DavidBo is offline   Reply With Quote
Old 04-15-2018, 03:19 PM   #13
If you really want those same gaskets, go to a hardware store and buy the least expensive stainless steel braided lavatory supply tubes you can. Pull the gaskets out of the large (1/2”) nut on the supply lines and use them. That is what those gaskets are.
Bruce
Old 04-15-2018, 03:32 PM   #14
Who Dares, Wins
doc73's Avatar
Originally Posted by nomad297 View Post
If you really want those same gaskets, go to a hardware store and buy the least expensive stainless steel braided lavatory supply tubes you can. Pull the gaskets out of the large (1/2Ē) nut on the supply lines and use them. That is what those gaskets are.
Bruce
Or borrow one from their lavatory...
2015 ChevyHD D-Max
Old 04-15-2018, 03:37 PM   #15
DavidBo's Avatar
At least you won't get caught on video...I hope!
Old 04-15-2018, 03:43 PM   #16
Who Dares, Wins
doc73's Avatar
Haha.. I'd scare them to death if they did....
2015 ChevyHD D-Max
Old 04-15-2018, 05:40 PM   #17
I like this idea, how are you guys attaching the valves to the drain tubes?
Old 04-15-2018, 07:38 PM   #18
Fluffywhitedogs's Avatar
Water Drain Plug
I lost one of those gaskets and couldnít find a replacement. I ended up just getting a rubber washer that fit snugly in the cap and that made a good seal, and cost maybe 30 cents. Iíd like to do the valve mod but I havenít been able to find one that turns easily. My drains are in an awful spot. I can get a cap off with one hand but all the valves Iíve seen in-store would take 2.
Carmen and the pack
2017 Dodge Durango Citadel 5.7 Hemi
Fluffywhitedogs is online now   Reply With Quote
Old 04-15-2018, 08:29 PM   #19
DavidBo's Avatar
The drain line stubs are standard 1/2 inch plumbing fittings. Your local home center or plumbing supply will have everything you need.
I used this:
https://www.homedepot.com/p/Apollo-1...212S/301541047
You'll need crimping tools for the PEX, might be able to rent something. You could also try finding similar stuff using barbed fittings with polyethylene tubing and hose clamps.
Old 04-15-2018, 08:45 PM   #20
See post #11 here:
Low point drains
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
drain, water
