Old 06-18-2019, 02:53 PM   #1
Water drip after filling water tank
Have 2017 Salem 27RKSS . Previous trailer was a Jayco 29N. When I filled the Jayco with water, I would fill til water started coming out overflow onto ground. 2017 Salem apparently does not have overflow. Now fill til I can hear water getting very near full. Then water drips out of area where water drain hose exits plastic liner under water tank. How do I know when to stop filling Salem with water if there is no overflow? Hope slow drip I get after currently filling/overfilling is not a serious issue but appears I cannot determine what is going on.Thank you
huskylover is offline   Reply With Quote
Old 06-18-2019, 03:00 PM   #2
There may very well be an overflow hose in the same area as the tank drain.
It may have never been routed correctly or somehow got pushed up inside the Coroplast. (plastic liner)
Have you tried to continue to fill once you "can hear water getting very near full."
Do you have a gravity fill or is your tank filled from the city water connection by turning a valve?
Days Camped: '16=46 '17=30 '18=51 '19=27
Old 06-18-2019, 08:00 PM   #3
I have gravity fill. When continued to fill when I hear water getting near full, the water starts coming out of the place (hole) where I am adding the water. No apparent overflow hose on my trailer. Water continues to slowly drip out until I remove a gallon or two of the extra water.
Old 06-18-2019, 10:37 PM   #4
NMWildcat's Avatar
Only way to know what is going on, and where your vent hose is, is to take down enough coroplast to investigate. Anything else is just a guess.
Scott and Liz - Southern NM
NMWildcat is online now   Reply With Quote
Old 06-18-2019, 10:59 PM   #5
SailorSam20500's Avatar
My Flagstaff doesn't have an overflow. It does have a vent hose that is connected to the gravity fill port. I've been able to fill until water comes out the port and then put the cap on - no drips.
I wonder if your vent tube is disconnected from the fill port and is hanging such that you get that drip.
Good luck solving the issue.
Al
Save the Earth. Its the only known planet with Beer.
S.E. Mich.
Flagstaff 26FKWS / 2018 F-150 3.5 EcoBoost SCrew
SailorSam20500 is offline   Reply With Quote
Old 06-19-2019, 10:26 AM   #6
Head Rambler
On the 29RKSS which is the fifth wheel version of the 27RKSS the vent/overflow for the fresh water tank is right behind the axles on the curb (door) side. There are also a couple of low point drains near the side wall a little further back. The vent in the gravity fill fitting is caulked closed because there's nothing hooked to it.
Take a look at yours and see if you see those pipes sticking from underneath the RV.
It's possible that the vent/overflow has came loose from the fitting in the tank.
Gotta go campin!
Bama Rambler is online now   Reply With Quote
Old 06-19-2019, 11:07 AM   #7
Sounds like a missing or loose clamp on a vent line.
Sami. my Shih-Tsu "Co-Pilot" R.I.P
Politically Incorrect since 1943
"Sometimes you're the dog, sometimes you're the tree"
2004 Nissan Titan
TitanMike is offline   Reply With Quote
Old 06-19-2019, 11:24 AM   #8
i doubt there's an "overflow" on any fresh water tank. Your previous trailer "overflow" was probably the vent. There should be a small screened vent right next to the fill port, that SHOULD be connected to the tank vent, might have fallen off or forgot to install. Like NMWildcat suggested do some looking around underneath for the vent line.
nayther is online now   Reply With Quote
Old 06-19-2019, 02:13 PM   #9
bikendan's Avatar
What about the FW tank drain or a low point drain, that's partially open.
Equalizer WDH
Old 06-19-2019, 02:27 PM   #10
There have been many reports where the vent/overflow WAS NOT hooked to the small screened vent on the fill port. The vent/overflow was routed beneath the R/V and a daub of sealant smeared over the small screen.
One poster even pulled the fill port out to make sure it hadn't fallen off and reported it never was connected and couldn't be connected, as the hose was routed elsewhere.
Not every R/V is the same, including like models.
tank, water, water tank
