Old 02-22-2018, 11:21 PM   #1
Water filter
Hello allÖ After searching the forms I discovered that most water filters are leaking which mine has begun doing. Iíve read that most people remove theirs and bypass completely. Before I take things apart and cause more damage, do I remove the top two hoses going directly into the filter and put them together? If correct how do I accomplish this and what types and sizes do I use? Any help would be grateful
methos987 is offline   Reply With Quote
Old 02-22-2018, 11:34 PM   #2
A 1/2" PVC coupler will do the job. Remove the fittings from the filter and screw them into the coupler.
Name:	half inch DURA coupling.jpg
My filter had PEX on each of the couplings. Smart folks say not to let the fitting rotate inside the PEX. However, I did. I let one fitting rotate in the PEX while I unscrewed it from the filter. Then you can rotate the filter to unscrew the other fitting. When putting the coupler in, I screwed the coupler to the 2nd fitting, then let the 1st fitting rotate in the PEX again when I screwed it into the coupler. I have not had any leaks in 3 years.
Name:	Filter replacement coupling.jpg
You seem to have a 90 degree fitting on at least one side. That will make it more difficult to unscrew. But it's not PEX. If it were mine, I'd remove the clamp on the white hose on the 90 deg fitting and pull the hose. Then you can unscrew the fitting easily. Put it back together with a good hose clamp. (Others will tell you no hose clamp, but I've had no issues with them in 6 years.)
Just my $0.02.
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 02-23-2018, 02:04 AM   #3
gectisme's Avatar
Water filter
X2, we had almost the same setup. Cut the clamp off the white hose. Remove the white hose from the 90. Take the whole filter off the wall and you can spin it to unscrew the 90 with PEX on it. Buy the coupler and a good hose clamp and reverse the above. 15 minute job.
2016 Windjammer 3006WK - Sold July 2018
2002 Lance Lite 835EC TC - Sold July 2015
2010 Dodge Ram 2500, 4x4, Diesel, Front Hitch, Air Lift 5000 Rear Air Bags, (not really used, left over from our truck camper).
MISSION COMPLETED!
gectisme is offline   Reply With Quote
Old 02-23-2018, 06:01 AM   #4
kdp1897's Avatar
How long did it take to start leaking? Just wondering what to expect with my 2017 Rockwood - which (knock on wood) is not leaking yet.
2017 Rockwood Ultra V 2618VS
2017 GMC Sierra 1500 SLT Crew Cab Z71, 5.3 EcoTec V8
Nights Camped: 23 (so far) in 2019; 39 in 2018
kdp1897 is offline   Reply With Quote
Old 02-23-2018, 09:57 AM   #5
If you have the FR1/KW1, don't wait. They can crack at anytime.
Old 02-23-2018, 10:29 AM   #6
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
Here is a tip:
Never try to remove the filter while the system is under pressure.
2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt AGM Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 02-23-2018, 11:11 PM   #7
Thanks for the help. And it took about 5 months to start leaking
Old 02-23-2018, 11:23 PM   #8
Kaadk's Avatar
We like our onboard filter and weíve had ours going on 5 years now with no leaks. Some have them, some donít. Canít really explain it.
However, mine is prepped with leak prevention measures. Actually, I did this to make winterizing easier, but as an added measure it can be used if it ever does start to leak:
Old 02-24-2018, 12:39 PM   #9
I simply cannot thank you guys enough. Just got done fixing the issue and no leaks so far. Cost about $10 to fix and the hardest part was getting that darn clamp off.
Old 02-24-2018, 04:52 PM   #10
$10.00? My coupler was only 67 cents.
I'm wondering what you spent the rest on. The clamp couldn't be more than buck, could it?
You didn't buy $9 worth of beer, did you?
water, water filter
