Old 04-25-2013, 07:20 AM   #91
caper's Avatar
If you want a 5 micro filter to be mounted outside, you could get a whole house filter(the same as inside the trailer) and have it outside of the unit. They make holder to sit the filter in when outside.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-25-2013, 07:39 AM   #92
TURBS's Avatar
Correct you are.
Old 06-09-2013, 04:27 PM   #93
How would I know which replacement water filter to purchase for a 2005 Forester? When it was dewinterized, a new filter was not added so I don't know what numbers to use to get another one to add it again. We have REALLY bad well water to use in our RV and will need a filter.
JSRob is offline   Reply With Quote
Old 06-10-2013, 10:50 AM   #94
redsuspenders's Avatar
First thing when we got our new roo was take out the interior filter. Left all the lines in same location and just put in a pex barb to reconnect line.
We have never had one before, so I don't see the point now.
redsuspenders is offline   Reply With Quote
Old 06-10-2013, 11:11 AM   #95
VinceU's Avatar
Its most likely 10" or 5" length, diameter per mfg but you measure your bowl for what will fit. Most have same gasketed ends.
Old 06-10-2013, 11:19 AM   #96
TURBS's Avatar
I think my canister has a pt. Number for filter right on it.
Culligan filters work fine.
Old 06-10-2013, 11:43 AM   #97
bob213's Avatar
You need to watch the flow rates of the filter you purchase. Filters from Home Depot or Lowes will work fine at filtering but can have a lower flow rate than a filter designed for an RV. If water is being pumped via your water pump this can make an even bigger difference. I bypassed my original so it no longer is served by the water pump. It's mounted outside and only filters water from the city connection. Here's some higher flow filters (although more expensive)
RV Water Filter Store: Standard Filter Canisters for Whole RV
and here's the original that came in my FR trailer:
http://www.flowpur.com/Merchant2/mer...egory_Code=RVF
bob213 is offline   Reply With Quote
Old 06-10-2013, 12:00 PM   #98
Why would a Home Depot whole-house filter have a lower flow rate than an RV filter? I don't believe it.
Old 06-10-2013, 12:13 PM   #99
TURBS's Avatar
The micron rating denotes flow rate not the brand or place u buy it.
Old 06-10-2013, 12:17 PM   #100
X2 as long as they are the same Micron#. Youroo!!
