Old 05-13-2014, 01:19 PM   #1
harpman's Avatar
Water Filter
We just bought a new TT in February..only had it out once..can someone tell me where the water filter goes..my manual is in the camper...not sure if I can get to it with the slides closed..I want to get it installed before Labor Day weekend..although I've heard so many people complain about the filter coming loose..do I really need to install?..it's a 831RESS btw
831RESS FLAGSTAFF
F150 FORD ECOBOOST
harpman is offline   Reply With Quote
Old 05-13-2014, 01:29 PM   #2
Kaadk's Avatar
They seem to be in different places in different models, but all will generally have them near the city water / water pump. In my TT that's under driver's side bunk in the bunkhouse.
Just go outside to where your water connections are. Whatever's inside the trailer at that point is where it's most likely at. If you have a storage panel nearby, try opening that and then looking towards the water hookups. If not, you'll have to go from inside.
Old 05-13-2014, 01:53 PM   #3
NELA
Weezer's Avatar
Ours is in a screwed shut (why the heck do they do that?) kitchen cabinet door.
DH is going to fill the screw holes and put a regular cabinet door latch on it. Makes NO sense to have to unscrew the door every time you want to check the filter system or replace the cartridge in the canister.
So, my advice is to look for a screwed shut cabinet door.
We also have the blue in-lite water hose filter so we're considering removing the in house filter altogether. I hear those cartridges are WAY expensive and can't be bought just anywhere.
If age is a state of mind, and I've lost my mind, I'm AGELESS, right?
Give me 40 acres and I'll turn this rig around:
Flagstaff 5er 2014 8528 IKWS, Platinum Package, Regency Interior "Buffy"
F250 Super Duty 2013 Tuxedo Black "Biff"
Days camped 2014: 30
Weezer is offline   Reply With Quote
Old 05-13-2014, 02:43 PM   #4
SKnight's Avatar
Honestly don't bother with the factory one, get one that goes between the hose and the unit such as one of the blue ones I'm sure you've seen. The factory water filter is junk.
Old 05-13-2014, 02:54 PM   #5
VinceU's Avatar
Personal preference of course, but you do get what you pay for. The hose filter (aka Walmart) will stop rocks and sand but that's about it @100 micron. The "factory" unit will filter chemicals and sediment down to 5 microns.
Old 05-13-2014, 03:24 PM   #6
harpman's Avatar
Thanks for the quick replies..have a pretty good idea where to look now
831RESS FLAGSTAFF
F150 FORD ECOBOOST
Old 05-13-2014, 03:54 PM   #7
Place a Good whole house filter on the outside of your RV. You can insert (Any element) You select the Micron & other (Things) you want removed from your water entering you RV! You can even (SEE) what is entering! Youroo!!
ID:	52329   Click image for larger version
Old 05-13-2014, 03:59 PM   #8
WFD
yooroo...with the whole house filter like you use mounted on the outside...what do you do with the filter in between trips when the trailer will be parked a while? The blue ones I was using from Walmart..I just put in the fridge between trips to prevent growth of different bacteria.
Rick
WFD is offline   Reply With Quote
Old 05-13-2014, 04:46 PM   #9
I have the exact same setup, change filters once a year, maybe twice, no growth algae etc. that I have noticed for the whole season.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 05-13-2014, 04:47 PM   #10
bikendan's Avatar
your owner's manual would be useless anyway, since it's generic and has nothing at all, regarding your specific model or brand of RV.
Equalizer WDH
water, water filter
