Old 05-28-2010, 11:25 AM   #1
Water Filter
I have a 2009 Rockwood 8280 ws 5th wheel. Where is the water filter located?
Thanks,
Mike
Okay,jokes over.
Now bring back the Constitution.
Proud parent of a U.S. Soldier!
2009 Rockwood 8280WS
2004 Chevy 2500HD Ext. Cab 4X4
m_ragan is offline   Reply With Quote
Old 05-28-2010, 11:34 AM   #2
I have a Cardinal and my filter is in the exterior cabinet on the driver side of the 5r where the cable TV connector, dumping valves and outside shower are located.
Big Bird
Big bird is offline   Reply With Quote
Old 05-28-2010, 11:42 AM   #3
Herk7769's Avatar
2010 8526 RLWS - the water filter in my unit is behind the basement wall next to the water inlet fitting.
PITA to get to to change the filter.
Need to do that every time you winterize, so I cut out a section of the plywoord with a box cutter to gain access to the cabinet from the basement. Goind to rebuild the entire system and add a surge tank to the water pump. Also add LOTS of sound proofing. The damn thing is NOISY.
HAM CALLSIGN - KC3FFW
Old 06-02-2010, 05:10 PM   #4
Big Bird
Mine is in side the camper under the TV console.
2005- WDF27RLSS
2001-Dodge-4/4- souped up Cummins
1953 Willys 4/4
1970 Restored Cushman Trackster
Olratlr is offline   Reply With Quote
Old 06-02-2010, 05:46 PM   #5
Dave_Monica's Avatar
On our 2010 8280WS, the water filter is in the lower cabinet between the stove and frig behind a removable partition. Water pump is there also.
Dave
Old 06-02-2010, 07:53 PM   #6
They are usually real close to your water pump
2008 8296SS Rockwood Signature Ultralite
2002 Silverado 2500HD extended cab
chevy02 is offline   Reply With Quote
