Old 06-11-2015, 04:39 PM   #11
Thanks, good to know if I ever have to connect two PEX lines.
roostershooter is offline   Reply With Quote
Old 06-12-2015, 09:19 AM   #12
deebarjay's Avatar
rooster
ID:	79713which minilite do you have? I have the 2309s and am trying to find out the reason for the line that goes up into the floor after the tee from the pump pressure side and also the reason for the black redirect valve that is before the pump.
deebarjay is offline   Reply With Quote
Old 06-12-2015, 10:28 AM   #13
I have the 2104 model. I think that black valve is switched when you are winterizing the camper, but I am not positive.
water, water filter
