Old 10-01-2016, 11:21 PM   #1
Water filter:bypass or remove?
I have a Rockwood Mini Lite 2304 with inline water filter. I usually use an external filter on the city water or the fresh water inlets. The Rockwood filter is kind of redundant and a pain to remove for winterizing. Should I remove the filter or keep it and put in a bypass? The inline setup uses 1/2 inch blue PEX lines. Removing the filter would be a negative should I sell the trailer down the road. What is needed to perform both options and where do find the parts needed?
Thanks.
rbrak29 is offline   Reply With Quote
Old 10-01-2016, 11:25 PM   #2
Ford Idaho's Avatar
A 1/2 threaded PVC coupler is what some have used, wrap the threads with a couple of loops of thread tape.
Remove the filter, put it in a box, store it for the next owner should there be one.
Ford Idaho is online now   Reply With Quote
Old 10-01-2016, 11:34 PM   #3
Here's what I put in my ML 2503S. 58 cents at Home Depot.
Name:	Filter replacement coupling.jpg
1988 Coleman Sequoia - popup (1987-2009)
2012 Roo19 - hybid (2012-2015)
2011 Traverse LT, 3.6L, FWD
2009 Silverado Ext Cab, 5.3L, 4x4, 3.73
rockfordroo is online now   Reply With Quote
Old 10-02-2016, 08:58 AM   #4
WFD
For about $5 you can also use a Sharkbite, readily available in any plumbing section of your hardware store...saves you from having to use a pex crimper. As far as it being a negative down the road should you sell it....I don't think it will make a difference, in fact the buyer might be happy you dealt with it and he/she won't have to. Many people don't want the inline filter. It's the first thing I modified and removed when I got our trailer home.
2016 Chevy Silverado 2500 Duramax
2016 Rockwood 8289WS, Diamond Pkg.
WFD is offline   Reply With Quote
Old 10-02-2016, 09:19 AM   #5
It doesn't leak and I don't use it so I just leave it alone.
2015 Cedar Creek 32RL
2012 Silverado 3500HD SRW
http://www.forestriverforums.com/for...ignhavefun.gif
spock123 is offline   Reply With Quote
Old 10-02-2016, 01:10 PM   #6
sfsgm's Avatar
I have a Cardinal. Our filter is right where I can easily twist if off and remove it for winterizing. I guess it isn't that easy for you. If I had the same situation, I'd bypass it, keeping the filter system in place. It doesn't take that much time to install a ball valve or something similar.
2016 Nike Take Down Wrestling Shoes
38 ft square Dollamaur High School Wrestling Mat
sfsgm is offline   Reply With Quote
Old 10-02-2016, 02:19 PM   #7
We also have the 2304 (KS model) I run the city water through a sediment pre filter before the inline filter. I completely agree with rbrak29 about what a pain it is to remove the filter for winterizing, or changing the filter.
So, I am curious about others thoughts and experiences with this ?
Denny B is offline   Reply With Quote
Old 10-02-2016, 04:53 PM   #8
CaptnJohn's Avatar
1st thing I do is purchase a filter and add it to the hose ~~ at the faucet. Always eliminate the in coach filter.
2016 Keystone Cougar 303RLS
2016 F350 diesel
Edgewater 205 EX 150 Yamaha
Old 10-02-2016, 04:53 PM   #9
Filter Options
On my Roo the filter and water pump were right in the way of using the pass through for any good purpose so I removed the filter and moved the water pump next to the water heater. Like you I use an external filter so the factory one make little sense and was in the way. Pex fittings, tubing and compression rings can be purchased at home depot. The compression ring tool is cheaper on Amazon.
DocRob is offline   Reply With Quote
Old 10-02-2016, 05:15 PM   #10
67hvymtl's Avatar
I also have a Roo with a cartridge filter that's installed in a floor cabinet underneath the front bed, but I also use an inline filter at the connection. I will be winterizing in a few weeks and will pull the cartridge filter. To me, no harm no foul - the water is double filtered. LOL!
2016 Rockwood Roo 233S Sapphire Package
2015 Chevy Traverse LS w/V92 tow package
67hvymtl is offline   Reply With Quote
bypass, water, water filter
