Old 11-27-2012, 12:30 PM   #11
TURBS's Avatar
Originally Posted by B47
WOW - only you would know "an oring guru"
Thanks - I will keep that on file.
He supplies o-rings and hydraulic supplies to Alcoa . If he doesn't have it or can't find it YOU DON'T NEED IT!
Old 11-27-2012, 12:31 PM   #12
Dallas Texas
TexasBBQ's Avatar
Don't take this the wrong way but if you're looking at it facing the housing remember you'll turn it CW to remove it. Sometimes folks forget....
2004 Cardinal 33CKT
2006 Ford SDD F250 CC 4WD
TexasBBQ is offline   Reply With Quote
Old 11-27-2012, 01:35 PM   #13
JDWeir's Avatar
Here is anothe place that has o-rings and filters ect.
Refrigerator Water Filters, Water Filters, Air Filters, Pool Filters, HVAC Filters, Filters Fast
TV, 2000 Dodge RAM 2500 Quad cab short bed, Cummins 5.9, Edge Comp, Gauges.
5ver, 2011 Palamino Sabre 31 RETS.
JDWeir is offline   Reply With Quote
Old 11-27-2012, 02:24 PM   #14
VinceU's Avatar
Heres the maker, has filters, gaskets and bowls, not cheap but will fit.
Water Pur Company CCI-10-C
Old 11-27-2012, 05:32 PM   #15
That's a good point, remember lefty loosie rightie tightie.
Of all the things I've lost in my life the thing I miss the most is my mind!
prairiecamper is offline   Reply With Quote
Old 11-27-2012, 06:30 PM   #16
vasnipe's Avatar
Left loosie, righty, what?
A blast from the past from my early Navy days
2006 Sunseeker 3100SS/LTD
2008 Smart Passion Cabriolet TOAD
1986 Honda Helix (Original owner)
vasnipe is offline   Reply With Quote
Old 11-27-2012, 07:15 PM   #17
Dovetail's Avatar
And if u can't remember that righty tighty thing, here is another way. Take your right hand and point your thumb to the way U want the screw, nut, bolt to go. Your fingers wil point in the correct direction to turn. Use your left hand for left handed threads.
Rick and Linda, Lindale, TX
2011 Flagstaff 8528 CKSS
2006 F350 SW
Camping nights 2013: 130
Camping nights 2014: 17
Dovetail is offline   Reply With Quote
Old 11-28-2012, 08:27 PM   #18
Sportracker's Avatar
Its called the right hand rule but remember some propane fittings are left handed threads. For those, you need to use your left hand
Sportracker is offline   Reply With Quote
