Old 11-26-2012, 05:30 PM   #1
water filter canister woes
I have tried to pull the water filter out by unscrewing the canister using the "wrench". For the life of me I cannot get the thing to budge. When I start really applying force to it, it wants to rip the screws out holding it.
I am pretty sure its not supposed to be that tight. Any suggestions? tips? etc?
dolson60174 is offline   Reply With Quote
Old 11-26-2012, 05:39 PM   #2
Herk7769's Avatar
Open a faucet.
ANY pressure will make that puppy REALLY hard to get off.
HAM CALLSIGN - KC3FFW
Old 11-26-2012, 05:46 PM   #3
Dave_Monica's Avatar
You've got to hold onto the top of the filter housing while using the wrench on the canister.
Dave
Old 11-27-2012, 11:32 AM   #4
Originally Posted by herk7769 View Post
Open a faucet.
That would make sense on the pressure...I will give that a try when I de-winterize in the spring! thanks!!
Old 11-27-2012, 11:43 AM   #5
B47
Slightly off topic - but speaking of water filter cannisters, does anyone know if or where you can purchase the "O" ring that fits into the cannister?
I am in the habit of always replacing an "O" ring (s) whenever performing maintenance on a compontment that has them - guess that comes from my aviation background.
I expected to get a replacement " O" ring in the box when I purchased my first replacement filter, but none was there. I also didn't see any at CW.
Thanks.
B47 is online now   Reply With Quote
Old 11-27-2012, 11:57 AM   #6
Thanks.
I would have to say find out who the manufacturer of that component is and contact directly or even a search on the interwebs may help. It maybe as simple as go down to HD or Lowes and find the right diameter...but again that could be TOO easy...
Old 11-27-2012, 12:01 PM   #7
B47
Thanks - I didn't think of doing an internet search.
Old 11-27-2012, 12:04 PM   #8
First, as said, make sure there is no water pressure. Don't know what size/type your filter is, but sometimes there is a pressure relief button on top of the unit.
There is a special lube that is made specifically for water filter O-rings and threads (Dow-Corning, eg.). Might try some of that for next time. Sometimes the O-rings can enlarge and not fit the canister easily, especially if the sn*t got squeezed out of it, so it might be wise to have a spare on hand. O-rings and the lube are available on the internet and at wholesale plumbing places.
If you have water inside the canister, you should get the filter out and empty it if it freezes where you are.
Gil & Deb & Dougal the Springer Spaniel
Langley, BC
myredracer is offline   Reply With Quote
Old 11-27-2012, 12:09 PM   #9
TURBS's Avatar
Thanks.
IF your search turns up no results call this guy ....
www.rodgersindustrial.com
hes an oring guru from way back.
Old 11-27-2012, 12:24 PM   #10
B47
WOW - only you would know "an oring guru"
Thanks - I will keep that on file.
