Mine is behind a false wall under the sink. Once you remove the panel you have access to your water pump, by pass system and your water filter. It should have been covered in your PDI, but often times there is too much info to retain. I am sure someone will chime in to tell you exactly where yours is located. You can always google it, tons of you tubes videos out there on camping.
Chuck " still in Va "
2012 3065w Windjammer
2012 f250 lariat Crew cab power stroke (of course )
