Old 06-02-2015, 12:35 PM   #1
Water Filter casing problem
Hello folks, newbie here, just bought a 2014 Georgetown XL378TS last month and am learning the systems. I tried to unscrew the casing of the oem water filter to put new filter in and it will not budge. Any thoughts? I don't want to break it, but it's just not going anywhere. thanks, rob
downlocked is offline   Reply With Quote
Old 06-02-2015, 09:14 PM   #2
Have you tried using the special tool (white plastic with grooves) supplied by FR to remove the filter housing ?
Black
2014 Ford F250 Lariat SuperCrew 4x4 tuxedo black
2015 Rockwood Signature 8310SS Diamond Edition
***3rd GENERATION EGG FARMER***
***WHO MADE YOUR EGGS TODAY ?
Black is offline   Reply With Quote
Old 06-02-2015, 09:22 PM   #3
dieselguy's Avatar
If it wasn't prepped with silicone on the threads and o-ring ... it's gonna be really tight the first time spinning it off. Like mentioned ... the grooved tool will help, but you may have to back up the housing somehow to keep from breaking a water line fitting.
dieselguy is offline   Reply With Quote
Old 06-02-2015, 09:27 PM   #4
Open a Fixture and release water pressure first! Youroo!!PS Welcome!
Old 06-02-2015, 09:42 PM   #5
deartruc's Avatar
Be careful. If its the KW1 style, the retention nubs may brake off (totally not your fault) so when you screw it back on with the filter, it will unscrew on its own and flood your camper!
2017 GMC Yukon
2015 Roo 23 ikss
deartruc is offline   Reply With Quote
Old 06-02-2015, 09:45 PM   #6
jtownstumpjumper's Avatar
Location: Jonesboro AR--Home of Arkansas State University and the Red Wolves
X2....open a faucet to relieve the pressure....then unscrew it.
Lloyd & Kathy & Kit(19 yr old cat)
2018 Forest River Palomino Columbus 383FB
2016 Chevy 3500HD SRW Z71 LTZ 4WD Crew Cab, DuraMax/Allison.
2014 - 38 nights/3500 mi.; 2015 - 66 nights/6260 mi.; 2016 - 44 nights/6106 mi.
2017-65 nights/6992 mi.; 2018-7 nights/1037 miles....9 nights booked
jtownstumpjumper is offline   Reply With Quote
Old 06-03-2015, 11:50 AM   #7
I had the same problem with my new unit. After 3 phone calls someone finally let me in on the secret. Turn on the taps top relieve pressure and it will come off.
tstanger is offline   Reply With Quote
Old 06-03-2015, 12:17 PM   #8
Location: Full timer,,,at Lake Georgetown in central Texas for the winter.
Also,,,,,push on the filter housing into the manifold as you're turning it off of the manifold. Makes it a lot easier.
Grampa Jim is offline   Reply With Quote
Old 06-03-2015, 01:27 PM   #9
I had the same problem. Tried everything suggested but nothing worked. Whoever put it on at the factory really cranked it down with no lubrication. Had to remove the filter mount from the trailer so I could grip it better, then used a strap wrench to get enough leverage to break the housing free.
frisbyh is offline   Reply With Quote
Old 06-03-2015, 02:20 PM   #10
I stopped fighting with it and the high cost of cartridges. I leave if empty and get Camco in line filters to hook on hose. Much cheaper at Wal Mart and lot easier to change.
Stlcaly is offline   Reply With Quote
water, water filter
