Old 10-16-2017, 02:31 PM   #1
Water Filter for Rockwood HW296
Hi all,
Two questions regarding the water filter in my 2015 HW296. Does anyone have the part number for this filter?
And 2, I just winterized the camper and forgot to pull the filter out of the housing. So it's just sitting in there in a bath of antifreeze. Obviously I will be replacing it in the spring, but I'm wondering if there is some reason I should pull it out of there before it goes under freezing? It's sitting in antifreeze so I suspect not, but just want to be sure.
Thanks,
Mark
julesva5 is offline   Reply With Quote
Old 10-16-2017, 09:30 PM   #2
SeaDog's Avatar
I don't have the part number for you, but you are correct there is no need to remove the filter now just replace in the spring after you flush the system.
Retired Navy
Jake my sidekick (yellow Lab)
2016 Flagstaff 26 FKWS
SeaDog is online now   Reply With Quote
rockwood, water, water filter
