Old 09-05-2009, 04:51 PM   #1
Water Filter in the SV264?
We are about to purchase an 2008 SV264.
Does anybody know where the water filter is?
I've searched the forum and can't find any posts with the location for an SV264.
rmgar is offline   Reply With Quote
Old 09-06-2009, 07:34 PM   #2
Dave_Monica's Avatar
We have a Rockwood 2605 which is basically the same floorplan. The water filter is in the pass-through storage area, curbside, above the water pump.
Dave
Old 09-28-2009, 07:04 PM   #3
On mine it is behind the removable panel next the oven.
41Chevy is offline   Reply With Quote
Old 11-08-2010, 10:33 PM   #4
Photodog
On my 264 the filter is right next to the water pump.
photodog is offline   Reply With Quote
Old 11-09-2010, 04:07 AM   #5
EastlakeRoo's Avatar
Mine was located in the pass-through storage area, curbside, above the water pump. It was such a pain to get at that I just recently removed the entire unit and will go with am exterior water filter that is attatched to the city water inlet connection.
2014 Wildwood 300BH
2014 Ford Explorer XLT
2011 Ford F350 FX4
Eastlake, OH
EastlakeRoo is offline   Reply With Quote
Old 11-09-2010, 08:26 AM   #6
bmg
My 06 SV 264 filter is to the right of the sink. We have one narrow panel that is held by 4 screws that is easily removed. The water filter housing is removed by using the plastic hex wrench, which should be laying on the floor next to it. It's an easy job to remove and not messy if you've drained the lines beforehand. I had replaced the filter element in the summer and we hadn't used it much. So for the winter I removed it, let it dry, put it in ziplock and put it in the freezer till spring. That way no bacteria can grow.
bmg is offline   Reply With Quote
