Old 11-03-2015, 06:10 PM   #1
Unhappy Water filter leaks when winterizing
We had filter canister off to change filter with no problem. Today we removed the filter and put the canister on tightly. Turned on the pump to put in the pink stuff and it leaked all over. Took off the canister and saw the O ring appeared too big it doesn't fully seat in the groove. Thinking maybe it stretched? Went and bought another one. Rubbed lube stuff on it and it fit in groove, tightened it in place. Still leaks. Any suggestions?
Once we get this to stop leaking it's not coming off again. Skipping the filter part and just using an outside one!
suscamper is offline   Reply With Quote
Old 11-05-2015, 07:09 PM   #2
MNtraveler's Avatar
Not screwed on straight/cross threaded?
2016 FR Forester 2401R
Towing 2014 Honda CR-V
MNtraveler is offline   Reply With Quote
leak, water, water filter, winter, winterize
