I have a 2004 Wildwood that had not been stored properly for the winter, thus I need a new plastic water filter canister and filter to go in it. I tried searching the web for one, but can't come up with the right search terms. I found this forum and thought I'd try here.
It is a BHSS30 if that helps. Anyone know where I can buy the stuff I need online?
Oh, this is a clear plastic thing that screws on to the system under the master bed, if that helps any. As you can see, I am a bit clueless here.
If your trailer came with the Water Pur filter kit, you can get a whole entire Dupont water filter housing kit for the price of just the replacement plastic canister.
If you want the Water Pur brand you pretty much have to get it from them.
Thanks! That looks like what is in the trailer. I have contacted them about the canister and the filter that goes in it. I appreciate the quick and very helpful response!
The Water Pur filter is sized the same as other filters on the market. Check the home improvement big box store of your choice for replacement filters.
2017 Chevrolet K2500HD
2009 Rockwood 2106 Mini-Lite
Be careful, they changed the canister a few years back. I drover 45 miles to get one, got home, found I had the 'other one'! The pacaging should tell what years they fit, there are only two of them.
