Old 12-28-2019, 02:04 PM   #1
GrayghostUSA's Avatar
Water Filter Plug
We have a Flagstaff 2019 26RBWS that came with a Waterpur RCS Housing using a KW1 filter. It is located under the bathroom sink cabinet in a very awkward position. When winterizing I remove the filter and throw it away. The housing then fills up with pink stuff. It is awkward enough that I can be sure of spilling some of it come spring when I am ready to flush out the system. Does anyone know of a plug that can be used instead of installing the filter housing? I would actually pay money for one.
GrayghostUSA is offline   Reply With Quote
Old 12-28-2019, 04:03 PM   #2
I tried one and it leaked. Different size, but same type. I just put a towel under it when removing.
Also, why waste all of that pink stuff. When I am finished winterizing I empty the filter holder in the toilet. The empty
AbdRahim is offline   Reply With Quote
Old 12-28-2019, 04:28 PM   #3
Kasual Kamper
You need something like this:
https://www.rvupgradestore.com/Flow-...-p/88-2435.htm
But really, you should consider just eliminating the filter all together and use one of the Campco filters outside attached to your hose. This process is discussed here and many places on the forum.
Current: 2013 Flagstaff MicroLite 21DS
Past: 2000 Fleetwood Mallard 19N
TV: 2013 Nissan Pathfinder SL 4x4
JayArras is offline   Reply With Quote
Old 12-28-2019, 04:51 PM   #4
DaGrinch's Avatar
Eliminate it. It causes nothing but aggravation. Use the blue CAMCO filter and forget it.
"Sunny" the 2017 Sunseeker 3010DS
2006 Jeep Liberty Toad
.... and lovin' life........MOST of the time.
DaGrinch is offline   Reply With Quote
Old 12-28-2019, 06:20 PM   #5
Mnflyboy's Avatar
Attachment 221086
I put a bigger size water bottle in the housing when I winterize. Cuts down on the amount of antifreeze that gets into the housing.
Jaye & Cindy
2007 Georgetown 349 XL
Mnflyboy is offline   Reply With Quote
Old 12-28-2019, 08:00 PM   #6
If you want to keep it, You can also install bypass kit around it, like you have on your hot water tank. That way you can bypass when adding antifreeze, or if you ever have a leak issue.
Or like others have said, eliminate it.
Your choice.
wvram is offline   Reply With Quote
Old 12-29-2019, 09:01 AM   #7
Thanks for the idea of dumping the pink filled filter in the toilet but once I thought it through I realized it just added to the number of steps under the sink. But thanks again.
Old 12-29-2019, 09:04 AM   #8
Thanks but I bought six filters, super cheap from the manufacturer at the F.R.O.G. rally last summer. So that is a six year supply and they were cheaper than the Campco filters.
Old 12-29-2019, 09:04 AM   #9
Attachment 221086
Old 12-29-2019, 09:05 AM   #10
Your choice.
Thanks, I like the idea of a bypass kit.
Old 12-29-2019, 09:28 AM   #11
DaGrinch's Avatar
Not to sound like a pessimist, but that's 6 years of unscrewing the canister, hoping it doesn't crack or spill water/antifreeze. The bypass does sound enticing, but then again, you still have to contend with emptying the canister of water. Make sure you get all the water out of the threads. Even that minute amount will freeze and crack plastic.
Good luck and best of travels with whatever you do.
Old 12-29-2019, 02:28 PM   #12
Here is the one I got, if you know bypass length needed, you can get different kits to accommodate the one you need.
https://www.amazon.com/Camco-35963-S...64732150&psc=1
Have a great weekend
Old 12-29-2019, 06:47 PM   #13
Most logical! Never thought of that.
water, water filter
