Old 04-21-2016, 08:44 PM   #11
Originally Posted by bitNine View Post
Yep. Even when not plugged, more effort is required to pull water through a better filter. Even if the difference is minimal, there is a difference.
I have to weight in here,I have NOT seen a "Suction Filter" on any RV ! The Filter is located to "Filter water From city Water and on the Pressure side of the F/W pump" there is a Small screen on the suction side of some Pumps but it is Not a Filter! Youroo!!
Old 04-21-2016, 08:59 PM   #12
Push or pull, it's moot. More restrictive filters will result in more work for the pump.
TV: 2016 Ram 3500 4x4 mega cab w/6.7l Cummins
Trailer: 2013 Palomino Puma 27SBU
bitNine is offline   Reply With Quote
Old 04-21-2016, 09:00 PM   #13
Global Nomad
Scheinin's Avatar
Water Filter
I use those blue inline Camco filters from Walmart. However, when I am filling my fresh water tank, I add a 5 micron filter, since I don't care how long it takes to fill.
Steven J. Scheinin
2015 RAM 3500 4X4
6.7L CTD Dually pulling a
2016 Cedar Creek 36CKTS
Scheinin is offline   Reply With Quote
Old 04-21-2016, 09:09 PM   #14
The KW1 is five micron. It is designed for use with this pump. It is a 10,000 gallon or one year filter. Retail price is $30. You cannot get this much filtration for only $30 in any store. Get them from the Forest River Electonics Division at the Rally three for $25. The only way they leak is freezing.
2016 Berkshire XLT 43a
TwiceTheIce is offline   Reply With Quote
Old 04-21-2016, 09:11 PM   #15
caper's Avatar
A smaller micron will plug faster than a larger micron as it will remove more debris. A plugged filter would starve the pump and could cause it to overheat.
The filter is after the pump, it will not cause it to starve. The restricted flow would be no different the just opening the valve part way and letting the water flow. It could cause the pump to cycle more often.
Terry and Janet
2008 3001W Windjammer
2007 Ford F150
Old 04-21-2016, 09:39 PM   #16
Camper
Tracer215AIR's Avatar
Big Blue 10"
I installed a big blue 10" under the bed that only filters the city water intake. This way the storage water and the pump have no issues. Depending on the frequency of camping, these will last all year and make setup/breakdown even easier when you don't have to disassemble the Walmart inline filters every time. FYI, every time you unplug the Camco activated carbon filters, their water drains out and the worst thing you can do once your carbon is wet, is to have it dry out until the next time you camp.
Here is a pic of last years filter: http://www.forestriverforums.com/Pho...php?photo=3838
This was a 5 micron. The better the first stage, the better your GAC/KDM55 will last. Since I have a small camper, I don't need high flow. So this year I'm going with the 1 micron. I will see how long it lasts...
Amazon $50 bucks for both, lasts all summer and makes water drinkable. Enjoy!
2013 PrimeTime Tracer 215AIR Touring Edition
2014 GMC Sierra 1500 Z71 6.0l
Nights Camping: 2013 - 15; 2014 - 25; 2015 - 35
2016 - 5
Tracer215AIR is offline   Reply With Quote
Old 04-22-2016, 04:30 AM   #17
JohnF's Avatar
Oh yes you can and for less money. No filter manufacturer can predict the life of a filter without knowing the water you're pushing through it. I've worked on water systems that would plug your 5 micron filter in less than a week.
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 04-22-2016, 05:33 AM   #18
JohnF's Avatar
I believe some prefer the filters on the outside of their campers as there is less chance of water damage if the filter should leak. That is my case and I will take the time to install my outdoor inline filter every time I hook up.
I’ve never read or heard that letting carbon dry out is detrimental to it. I would be interested in more information on that.
I also believe many people are confused about micron size, carbon and safe drinking water. The filters many of us are using have both a mechanical filtration function (expressed in micron size) and the adsorption properties of the carbon material. If your concern is “safe” drinking water, don’t be so concerned about the micron size. The small pieces of debris that the mechanical filter removes are not likely to harm you as most are dissolved compounds of magnesium and calcium. In my opinion anything equal to or less than 30 micron is adequate.
Carbon is a terrible mechanical filter. It does its job by bonding contaminates to its surface (adsorption). They are generally called taste and odor filters as they remove chlorine and other chemicals giving you a better quality water.
Going to a 1 micron filter will not extend the life of your carbon but will reduce the life of your filter. IMO
John
Ohio
2015 Ford F-350
4WD SRW Diesel
Old 04-22-2016, 08:05 AM   #19
TandSH's Avatar
+1. And if the filter was completely clogged would be the same as if all water taps were closed. Again, not an issue.
2017.5 Cedar Creek 34RL2
2018 F-350 Lariat CC SRW PSD 4x4
USMC Fighter Pilot (Ret)
TandSH is offline   Reply With Quote
Old 04-22-2016, 08:26 AM   #20
JohnF's Avatar
I agree. Filters being installed should be after the pump.
Ohio
2015 Ford F-350
4WD SRW Diesel
pump, water
