Old 04-21-2016, 08:17 AM   #1
Water Filtration and Pump Concern
I am at the point of buying a new water filter. My current filter is KW1 which I read has a 30 micron filtration. Should I stay with a similar micron rating or get a better 5 or 10 micron rated filter. My main concern is flow rate and pressure and mostly the possible damage or strain on the water pump. Am I over thinking this filter decision?
TV- F150 FX4
TT- MicroLite 23FB
Tent2TT is offline   Reply With Quote
Old 04-21-2016, 08:25 AM   #2
Are you talking Filter change or Element? If Element what choice do you have from KW1? 30 is pretty coarse! Youroo!!
Old 04-21-2016, 09:17 AM   #3
Good catch. I am going to replace the filter housing so that I can buy a standard 10" filter from Amazon or local stores. I am gathering information as to which filter I should buy. i.e.- 5, 10, 20, or 30 micron filter.
TV- F150 FX4
TT- MicroLite 23FB
Old 04-21-2016, 09:25 AM   #4
Many of us have taken the housing and put it outside. very easy since you are planning to replace the entire thing anyway.
I replaced mine with a Home Depot special, it will take 30 or 5 micron filters. I like the 5 better, but i probably only think that because i know the filter I used.
2015 Ram 2500 4x4 6.4l with 2015 Sandpiper 25RLS
Wife, myself and 2 furry kids
Mountndream is offline   Reply With Quote
Old 04-21-2016, 09:26 AM   #5
bubbles's Avatar
You are over thinking possible pump damage. Type of filter has no influence on pump longevity.
Old 04-21-2016, 11:51 AM   #6
I just took out the factory supplied cartridge and left the housing. I use inexpensive inline Camco filters and change them twice a year. Amazon or Wal- Mart have them all the time. Makes winterization a lot easier.
2014 MiniLite with
Nissan Frontier
Stlcaly is offline   Reply With Quote
Old 04-21-2016, 02:26 PM   #7
Smile Suggestion
I took forum advice this Spring and went with an outdoor filter. I removed the cannister completely by cutting the pvc on both sides and joining the water line with a shark bite connector. I will be using the in line Camco filterson the outside on my water hose. No more winterizing that cannister or buying the expensive filters for it.
JHurtgen is offline   Reply With Quote
Old 04-21-2016, 03:01 PM   #8
JohnF's Avatar
A smaller micron will plug faster than a larger micron as it will remove more debris. A plugged filter would starve the pump and could cause it to overheat.
Ohio
2016 Cedar Creek 36ckts
2015 Ford F-350
4WD SRW Diesel
JohnF is offline   Reply With Quote
Old 04-21-2016, 03:14 PM   #9
Yep. Even when not plugged, more effort is required to pull water through a better filter. Even if the difference is minimal, there is a difference.
TV: 2016 Ram 3500 4x4 mega cab w/6.7l Cummins
Trailer: 2013 Palomino Puma 27SBU
bitNine is offline   Reply With Quote
Old 04-21-2016, 03:14 PM   #10
After reading the leaking problems due to the filter housing, I disconnected the filter housing and just bypassed my filter. I use those blue inline Camco filters from Walmart.
2015 Flagstaff 26VFKS
TV - 2014 F150 Crew Cab 5.0L
WDH - 1,200 Equalizer
txredfish is offline   Reply With Quote
pump, water
