Old 05-19-2011, 12:12 PM   #1
water heater
I have A 2007 rockwood signature ultralight 8314ss.
need some info how often do you change the anode and what kind do you use aluma or magnesium?
Kevcon62 is offline   Reply With Quote
Old 05-19-2011, 12:33 PM   #2
Your better off asking with the make/model of the hot water heater then the camper. If you have an anode and not a plug I believe that's a Suburban hot water heater. Anode life depends on how often it's wet and quality of water. Suburban says to replace when it's 3/4 gone. Atwood's do not require a sacrificial anode.
brianb is offline   Reply With Quote
Old 05-19-2011, 01:08 PM   #3
MtnGuy's Avatar
This anode rod has been used 2 camping seasons, and has plenty of life left.
On a Suburban water heater, it takes a 1 and 1/16th inch socket for the anode rod/drain plug.
