Old 05-23-2011, 09:31 PM   #1
water heater
Hi need help, tried starting my suburban gas water heater,it lights up and goes off 2-3 minutes later.Try turning switch back on and doesn't work,apparently there is a lockout,which I don't understand the way it functions.
john42 is offline   Reply With Quote
Old 05-23-2011, 10:01 PM   #2
sherdep's Avatar
shameless plug for trailer Info so we know if it is a Gas and Electric or just gas.
Do you purge the gas line out before starting it up?
starting the burners on the stove before the water heater?
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
sherdep is offline   Reply With Quote
Old 05-23-2011, 10:31 PM   #3
Iggy's Avatar
Does this happen when plugged into short power and also when on battery?
Check your batter voltage as I think you must have 12 voltDC to mak eit work. May be weak?
Old 05-24-2011, 04:54 AM   #4
dretired's Avatar
water heater
When we tried our water heater on the first trip. It would fire up then stop after a while. and sometimes not fire at all. My wifes uncle who happened to go with his rig to the same campground . Suggested i check the battery connections. Sure enough i could wiggle the neg wire. I tightend the wing nut and now it fires up and stays on. hope that helped
dretired is offline   Reply With Quote
Old 05-24-2011, 06:49 AM   #5
KyDan's Avatar
John we can better help you if you give us a little more info.
What year is your RV??
What brand and model is your water heater? (that info should be on
a sticker inside the burner access door)
Does it light again after sitting a while.
Is this the first time it's done it?
Peace!
Dan & Rita D
Blue Ox WD hitch
KyDan is online now   Reply With Quote
Old 05-24-2011, 08:00 AM   #6
The water heater is a gas water heater tried lighting the stove no problems there,then tried lighting heater again same thing happened.Worked fine last,everytime I start it up the flame comes on and goes out 2-3 minutes later have tried it at least 5 times.The rv is a 2010 forest river shamrock 19'.
Old 05-24-2011, 08:23 AM   #7
Herk7769's Avatar
Some troubleshooting help:
http://www.ducktec.com/waterheater-t...-shooting.html
HAM CALLSIGN - KC3FFW
Old 05-24-2011, 08:49 AM   #8
Iggy's Avatar
I would then try cleaning out the tube between the piot light back to the air vents in the tube. Many time mud dobbers or spiders build nests and clog the hole. I have seen this many times after not using a rig for awhile or over the winter.
Try it with some type of small flexible rod
Old 05-24-2011, 09:16 AM   #9
prof_fate's Avatar
Does the pilot stay lit on 'run'? You can get carbon buildup on the thermocouple that acts as an insulator and that can shut off the gas flow. A bit of sand paper will fix it.
My problem is wind blowing out my pilot and I don't have an elec start model or elec heater element.
Chris, Wills (16) Evie (13) & Toby our collie (6)
2011 Grey Wolf 28BH
2013 Chevy K1500 Crew w/ Reese StraitLine Dual Cam
Nights camped 2011: 11 2012: 18 2013: 12 2014: 12 2015: 13 2016: 56 2017: 8+
prof_fate is offline   Reply With Quote
