Old 10-14-2011, 04:04 PM   #1
Water heater
I think my water heater is causing power surges to my Cardinal 41ft 5thwheel. I have turned it off at the electric switch in the unit, however, how do I get it to work on propane only.
Soapdish3 is offline   Reply With Quote
Old 10-14-2011, 04:13 PM   #2
There should be a switch on the control panel. It is probably marked W/H. Probably next to the water pump switch. Turn it on and it should light up red. As long as the propane is turned on and you have gas in the tanks it should light off.
Old 10-15-2011, 05:44 PM   #3
TURBS's Avatar
why do you think your hw heater is causing power surges ?
