Old 04-21-2012, 09:01 PM   #11
fast murray's Avatar
Our setup is different in that it has just one valve that can be rotated a 1/4 turn. I've never actually seen it because you have to feel for it but it is there.
2004 Wildcat 28BH
2012 Ram 2500 CCSB 6.7CTD
fast murray is offline   Reply With Quote
Old 04-21-2012, 09:35 PM   #12
VinceU's Avatar
Originally Posted by wildpop View Post
NO the dealer did not show me. They did a basic walk through and nothing more. I found nothing on the back of the wqater heater no switch, no nobs nothing.
Here's the key to the forest! I had the same problem 1st night out. The only access I know of to a wtr htr in 378 is through a 3" white screwed plug just under the access door. Unscrew it reach up in the the back of the heater and your'll soon realize which is the bypass valve. Inlet at bottom, outlet at top and bypass in the middle all towards front of coach. Close it, make sure other two are open, it water will now fill heater and you can start gas or electric.
Old 04-22-2012, 04:52 PM   #13
Thanks Herk. I went out this morning and my newhew and I found the hole under the motor home where the valve is.
wildpop is offline   Reply With Quote
Old 04-28-2012, 09:30 AM   #14
rracer5's Avatar
The "Herkbrary" comes through again !!!! I guess my "tag" for you is going to stick, Lou ! Again, thanks for being there.
"PT Crew Members Since 9/2010"[/I][/B]
2014 Sanibel 3250
rracer5 is offline   Reply With Quote
