Old 04-20-2015, 07:48 PM   #11
Model # SW6DE Ser# 032501599
lyc1970 is offline   Reply With Quote
Old 04-20-2015, 07:53 PM   #12
Most water heaters come with 130° dual thermostats, one for 110v and one for propane. I haven't seen a 140° thermostat furnished standard in the 40+ yrs I've owned trailers. I changed both in my 5er from 130° to 140° to have more hot water available.
Old 04-20-2015, 08:40 PM   #13
Crockett's Avatar
Guy wants less heat from his water heater...can yo u help him out??
Crockett is offline   Reply With Quote
Old 04-20-2015, 08:47 PM   #14
Suburban 520788 Thermostat Limit Electric 120 Degree Trailer Camper RV
Old 04-21-2015, 11:58 AM   #15
Why not just open the cold side of the faucet more when running water?
Iwritecode is offline   Reply With Quote
Old 04-21-2015, 12:04 PM   #16
fonzie's Avatar
Usually it's because people don't want their children to get scald/burn from excessive hot water......
Fonzie
Old 04-21-2015, 03:22 PM   #17
hot water
We turn cold on first and just crack the hot and its scalding...
Old 04-21-2015, 06:50 PM   #18
That's what I was told many, many years ago and what we taught our 2 boys. We had an electric water heater when we were growing up and my mom insisted it be set to 145°, so it didn't take much to convince us to turn the cold on first.
Old 04-21-2015, 11:05 PM   #19
I have an Atwood GE16EXT water heater and I have a 'tempering valve' behind it. This allows cold water to be mixed with the hot at the water heater. You can then adjust it to give whatever temperature hot water you want. FWIW on my particular water heater it holds 10 gallons of water but they rate it as a 16 gallon as I believe the thermostat is set at 140 and by mixing with the cold it extends the supply. Apparently the previous owner had the tempering valve go bad and just took it out of the system. Hot water would dang near scald you and especially in the shower just a small nudge of the faucet would change from ice cold to scalding hot. I used a Watt tempering valve as a replacement. The stock Atwood tempering valve which is apparently prone to failure, is about $150. I found my Watt tempering valve on ebay for $29.
Steve
4x4FF is offline   Reply With Quote
Old 04-21-2015, 11:11 PM   #20
Crockett's Avatar
Atwood xt
It stores water at 160 and mixes to 130. I was a little nervous about the life of a tank at that temp. How is yours and hows it working?
heater, water, water heater
