Old 04-20-2015, 02:06 PM   #1
Water Heater
I am new to this trailer and didn't receive the owners manual. We are trying to figure out how to turn the water heater down when plugged in to 110. It's a 2004 Wildwood trailer. Thanks for the help.
Leslie
lyc1970 is offline   Reply With Quote
Old 04-20-2015, 02:31 PM   #2
Crockett's Avatar
non-adjustable thermostat...almost 100% sure....lol aftermarket adjustable may be available. i trade what I can find for your model number
Crockett is offline   Reply With Quote
Old 04-20-2015, 02:32 PM   #3
If you mean to lower the temperature then you are out of luck. The water heaters come with a fixed thermostat. You may be able to find a thermostat at a lower temperature but then the water would always be cooler.
Ontario
Vibe 6501
1 Prospector Canoe
2 Mtn. Bikes
4 Hiking Boots
Happy Vibe is offline   Reply With Quote
Old 04-20-2015, 02:35 PM   #4
Crockett's Avatar
for a while they came out with 140...then I think the MFG dropped to 120. got a model number??
Old 04-20-2015, 02:45 PM   #5
Not sure of the model number for the Vin last 7 are C037580 if that helps
Old 04-20-2015, 02:47 PM   #6
TURBS's Avatar
Almost all of your appliance manuals can be found online at the manufacturer's web sites.
All you'll need is the model number of the appliances.
TURBS
08 duramax tuned n modded, 32bhok Sabre
2015 camping "2 nights"
Old 04-20-2015, 02:51 PM   #7
fonzie's Avatar
If you have a by-pass winterizing valve on your water heater, you can open it slightly to mix some cold water with hot water to bring temperature down......
Fonzie
Old 04-20-2015, 03:31 PM   #8
Mr. Dan's Avatar
You'll definitely need your model number for other purposes. Look on the side of the trailer near the entry door. There should be a decal, etc., with the model number.
SEARCH is your friend!
Nights Camped: '13 = 49 / '14 = 74 / '15 = 74 / '16 = 85 / '17 = 110 / '18 = 28; booked = 34
Old 04-20-2015, 03:49 PM   #9
TURBS's Avatar
I think what was implied was a model number for the water heater.
TURBS
Old 04-20-2015, 04:20 PM   #10
Crockett's Avatar
oops...i guess thats my fault. can we get a look in the water heater door?? get a model number??
heater, water, water heater
