10-25-2014, 09:34 PM
water heater anode
2014 Sabre 34REQS-6
10-25-2014, 09:48 PM
The magnesium rods eat up quick...
2010 Georgetown 300FWSSouth Florida
10-25-2014, 09:52 PM
Oklahoma Proud
That's pretty normal for one season. There will only be a wire about the size of an oil dipstick when the anode is gone. At the rate yours is going, it should last 5-10 years i would think.
The crap in the tank is minerals and particles from the anode corrosion/ residue
10-25-2014, 09:58 PM
Ok so this is still ok and not in need of replacing?
2014 Sabre 34REQS-6
10-25-2014, 09:59 PM
Also we usually leave our drAin plug out of the tank for the winter and replace cone spring. Should we not do that with this type? Is plumbers tApe ok to use on the threads of this?
2014 Sabre 34REQS-6
10-25-2014, 10:01 PM
Correct. You may want to get/make a flush wand and hook to a water hose to flush the gunk out since you have the anode removed.
If you will look in the FAQ section under water heaters, I think Herk has an anode usage chart that shows you the various stages and at what point to replace it.
EDIT: Here you go
http://www.forestriverforums.com/for...aqs-36254.html
2011 Flagstaff 831 RLBSS
10-25-2014, 10:04 PM
Thanks gonna go check it out now
2014 Sabre 34REQS-6
10-25-2014, 10:18 PM
Oklahoma Proud
We leave ours out too over the winter and flush the tank. I would reuse that anode, as i stated before, the wear rate on yours, it should last for years.
I've heard varying views on the tape, but i was under the impression that it needed direct metal to metal contact with the tank to be of any use as a sacrificial rod....but i might have misunderstood that, but it makes sense.
10-25-2014, 11:03 PM
Just a member
Indeed, lots of miles left on that one.
K&L + the Wild Bunch
TT: 2011 Rockwood 8293RKSS
TV: 2019 Dodge 3500 SRW Crew HO CTD
10-25-2014, 11:05 PM
Just a member
Depends on the water. We have four seasons on a magnesium anode.
10-25-2014, 11:22 PM
Ok thanks guys. Still learning g lots of new things different on this fiver from my old tt.
2014 Sabre 34REQS-6
10-26-2014, 12:01 AM
If you don't want it I'll take it. LOL If you're going to leave it out, might not be a bad idea to give it a roll in some baking soda. Then just rinse it well before you get going next season.
10-26-2014, 01:09 AM
What will the baking soda do?
2014 Sabre 34REQS-6
10-26-2014, 01:43 AM
Short story.. helps retain the efficiency of the surface area of your anode so less energy is required to bring your water temps up. Not a major deal, but as long as you've got it out anyway, right? :-)
10-26-2014, 01:59 AM
Interesting. I will have to look into doing that.... probably after I get my fiver back from the factory, that way if someone puts it back in I don't have to worry about it.
2014 Sabre 34REQS-6
10-26-2014, 02:08 AM
Just a member
Huh? Totally missed this in RV 101. How about that electro-chemical neutralizing thingy?
10-26-2014, 05:44 AM
Baking soda is the po'man's version. Since magnesium is electrochemically active, the baking soda helps to dampen the release of electrons as well as absorb ambient moisture and form an O2 barrier.
That was the long story.
It's not THAT big of a deal. It's not like they are really all that spendy to begin with, so longevity isn't so much an issue as efficiency when in use. Didn't mean to make a thing of it. Just one of those little things you pick up along the way from somewhere or other.
If you happen to have it out for an extended period of time. It just takes a couple of seconds to roll it in some baking soda and drop it in a baggie.
You can always just run some steel wool over it before you reinstall it, but that doesn't do much down in the pits. KWIM
10-26-2014, 05:52 AM
The back of the packaging for the OE anode states to wrap the threads with teflon tape. I seem to remember the rods actually coming with a small amount of tape in the package, but this may be incorrect. I think I have a new packaged one in the trailer and will take a look later.
10-26-2014, 07:44 AM
If you elect to leave it out, I would suggest rolling a pc of paper towel and plugging the hole to prevent critters, etc. from getting in. Wiping the threads with a silicone paste will also prevent the threads from rusting.
10-26-2014, 07:51 AM
Oklahoma Proud
Good to know! I couldn't remember. I was just gonna look at my anode when i pulled it out and see what the threads had.
But i usually use pipe dope instead of Teflon tape, just a habit from doing hydraulic line work.
