Old 11-10-2014, 06:22 PM   #31
BillyBass's Avatar
Originally Posted by Jhochst View Post
The camper is brand new this last September. Probably need to replace. We have bad hard water here. Attachment 66182
That looks pretty good
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 11-10-2014, 06:34 PM   #32
BombDoc's Avatar
Originally Posted by BombDoc View Post
That actually looks pretty good. You have several more months left on that rod in my opinion. I'll try and snap a pic of mine when I get home. I usually replace it when it is about half gone.
I was going to try and get a pic for the OP but my water heater is full and I don't want to drain it as I'm headed out Friday. Sorry, I will snap a pic when I do drain it and if this thread is still active (seems like it will be ), I'll post it when I do.
John & April & "Scout"
2013 Sabre 32RCTS-6
Nights Camped 2013-(44) 2014-(59) 2015-(47)
2016-(32) 2017-(13) 2018-0
BombDoc is offline   Reply With Quote
Old 11-10-2014, 08:39 PM   #33
mud yapster's Avatar
Yours looks a lot better than mine. Looks like you have 80% left. I'd wait and replace it later down the road. See how it looks in a few more months.
2014 Palomino Columbus 3650TH
435AH 12V VMax Charge Tanks, 520 watt Monocrystilline Solar Array, Morningstar MPPT TS-60 CC,Morningstar Remote,Cotek True Sine Wave Inverter,Cotek Remote Controller,50amp Progressive Hardwire Surge Protector
2015 Dodge 3500 6.7L 4X4
2011 CanAm Commander XT 1000
mud yapster is offline   Reply With Quote
Old 11-10-2014, 08:46 PM   #34
Iwannacamp's Avatar
I am no expert either... NPT or IPS is a tapered thread designed to seal on taper. The thread "lubricants" are partially designed to lubricate the threads during assembly. Many pipe fitter/plumbers use tape and paste at the same time. They make metallic pipe "dope". If you are worried about contact and corrosion at the same time...then use that.
2017 Puma 297RLSS
2005 Ram 2500 4X4 diesel
Our new 5er 10-26-16
Old 11-10-2014, 09:00 PM   #35
Mrs Evans's Avatar
So here's a recent story sorta related to this thread
When we brought our trailer home to prepare for our upcoming trip we wanted to clean our water system, including the water heater because of the rotten egg smell we experienced during our past 2 trips - first time we smelled it we had no idea what was wrong, during the second trip around October 10th we figured out the problem (thanks to the forum) but we didn't have the tools needed for the job so we figured we'd wait until we prepare for our next trip which is now.
Well as we begin, DH releases the pressure value and low and behold hot water comes out! Yes, we had actually left the water heater on since our last trip that was over a month ago! Total newbie oversight! Thankfully no one was hurt, including the tank since is was full of hot water.
Wish I had taken a pic of the anode, it was like almost gone even though we just bought the trailer in March 2014 and you can see in my signature that we haven't had that many nights camping. I'm glad I had bought a couple of anodes to have on hand so we were able to replace it. So much scale came out of that tank, yuck! We cleaned the whole system with bleach water, but we're also going to put vinegar through the system, seems like that would do a better job of removing the scale.
And I'm never going to forget to turn off the water heater again when we break down camp. Ever!
Michelle Evans
Katy, TX
2011 Carriage Cabo 341
2014 Wildwood 231RBXL - Traded Her In
2016 Days Camped = 5; Reserved = 14 so far
2015 Days Camped = 24 / 2014 Days Camped = 23
Mrs Evans is offline   Reply With Quote
Old 11-10-2014, 09:19 PM   #36
B47
[moderator edit - removed quote no longer in thread]
Me too. Especially when considering that the OP was just asking opinions about the remaining life of his anode Rod.
BTW - the threads on his anode Rod look prettry dang good to me and it looks like tape was used by the previous installer.
Old 11-10-2014, 09:25 PM   #37
Mrs Evans's Avatar
Agreed and it'll probably be good for quite some time providing he doesn't run his water heater for a month straight
You know that commercial with the owl about 'How many licks would it take to get to the center of a tootsie pop', well I can now share 'How many days straight running your water heater in an average of 90 degree weather that it would take to use up your anode rod' and your propane tank too! Not really funny, but I'm thankful everything ended up alright
Michelle Evans
Katy, TX
Old 11-10-2014, 09:30 PM   #38
B and B's Avatar
This is a correct statement that supports Glens experience with his anode now if we have a cathode ray tube I can claim to be an expert broadcast engineer...
I have use pipette pipe dope on my anode, lubricates the threads when I didn't have tape handy.
2017 Heartland Bighorn 3575 Elite with Reese Sidewinder
2016 Ford F 350 SD PS 6.7 SRW Crew Pucks and Reese 18 K Elite
2013 Rockwood 8289WS 2012 Rockwood 2703 SS TT 2007 Golden Falcon 38FLA PM 1983 Corsair 21RB
2015 Ford F250 PS '13 F150 3.5 Eco '09 F150 5.4 l 1987 Merc Grand Marq 1982 Ford E250 CW
Old 11-10-2014, 10:08 PM   #39
asquared's Avatar
These pics were taken when I removed my anode rod to winterize a couple of weeks ago. What you see in the pic is tape on the threads. This is original from the factory. The tape is peeling up a bit but not bunched up or acting as a nut.
<a href=http://i62.tinypic.com/28rp645.jpg target=_blank>http://i62.tinypic.com/28rp645.jpg</a>
2014 Sabre 34REQS-6
asquared is offline   Reply With Quote
Old 11-10-2014, 10:19 PM   #40
Looks like it had plenty of metal to metal contact regardless of the tape.
youroo, me thinks galvanic action takes place regardless of whether there is 110v ac available, unless my chemistry teacher lied to me.
anode, heater, water, water heater
