10-25-2011, 04:36 PM
#21
I am including a picture of my anode condition. The trailer is a minilite 2011. Most of the anode is not too bad but near the plug is is quite gone. I am not draining my water heater between the camping sessions. I just drain it at the end for winterizing.
10-25-2011, 04:39 PM
#22
That doesn't look bad at all. I just reinstalled mine and it looks almost exactly like that.
10-25-2011, 04:49 PM
#23
That photo is a great example. When the anode rod is in need of replacing, the entire length of it will look like the "eroded" end near the plug.
...VTX-AL
10-25-2011, 06:58 PM
#24
Soft water (anode)
Just to clarify something. Hard water will actually extend the life of the anode. Soft water will shorten the life of the anode. We usually don't run into this issue with TT or RV's. If you have a water softerner in your home installed before the hot water tank the anode will last one to two years. Don't ask me how I know . (Replaced under warranty though )
Giff
10-25-2011, 07:07 PM
#25
after draining ours and blowing the lines i just lay mine by the water heater and close the door leaving it open till spring when ill sanitze flush and use oh by the way i have put in one ner anode rod since my camper was new in 06 i clean it up real well before reinstalation every year
10-25-2011, 09:11 PM
#26
Lottery Non-Winner
Why is the anode rod/plug so hard to unscrew? On every camper/RV I've owned, it was tough as heck to unscrew them. I'm always afraid I'll break something because I have to torque it so hard before it starts to budge. I have one now that I have yet to get out. Why don't the heaters have their own low point drain VALVE?
2011 Georgetown 337
2009 HD FLHTCU
2007 HD FXSTC
10-25-2011, 09:15 PM
#27
good question ovair ! I wonder why they don't put a low point on the hw heater if I had to guess it would have to do with safety .
a half inch breaker bar and a good socket will get that puppy out !
10-25-2011, 09:18 PM
#28
That anode looks exactly like the one that is in our Salem that was brand new in the spring.I thought it was in need of replacing.Is it ok to use it next year looking like that?
2011 Salem 30kqbss
2013 Ram 2500
2005 Ram 2500
1968 Pontiac Le Mans
10-25-2011, 09:27 PM
#29
malco if yours looks like that then put er back in buddy !
10-25-2011, 09:43 PM
#30
Ok dumb ? Coming! What's an anode?, where do I find it? And why do I need to know about this anode thing?
10-25-2011, 09:45 PM
#31
its in most water heaters in the bottom portion of the tank .
keeps the tank from corroding .
10-25-2011, 10:58 PM
#32
i usually think of cathodic protection like electro plating. the impurities in the water make it conductive. the greater the mineral content, the more conductive. to keep the metal from the wh from being used, they put a sacrificial metal rod in there.
i haven't seen one on a gas only wh. that makes me believe the electric current passing thru the wh element plays a major part in the need for protection.
i would speculate that they don't put a drain on the heater to make u pull the rod and inspect. that may not have been their intent but it sounds good.
10-26-2011, 07:17 AM
#33
If my anode looks like the photo I supplied is there a special rod that hold the anode together since mine is almost gone near the treaded plug. I was afraid that the rest of the anode would separate and fall inside the water heater?
10-26-2011, 07:34 AM
#34
The wire rod itself should not deterioration....just the zinc or aluminum surrounding the rod.
Huh ?? I have always heard and read that hard water is the culprit of galvanic exchange.
Mine was hard to remove the 1st time.....the workers at the factory made sure that puppy didn't leak. I too was afraid of breaking something or messing up the threads. I used a 1 1/16th inch socket, and a small breaker bar with a lot of elbow grease. Since then, I have used thread tape, and I don't overly tighten the plug. If it leaks a little, I will give an extra little twist. When I pull the plug, there is no problem now.
10-26-2011, 07:35 AM
#35
Nope, my last TT was gas only and it had a anode. That one lasted 6 years before I replaced it, it probably could have went longer.
10-26-2011, 07:51 AM
#36
Vols, the anode rod is on the back side of the water heater drain plug on many water heaters. Some Atwoods do not use an anode.
An anode is a sacrificial rod that gives up its metal so other metals in your water heater will not corrode. Anode rods are usually made of aluminum or zinc, which more readily give up its molecules than other metals such as steel. Without the anode rod in place, your water heater would start to corrode due to the conductivity of water, especially water containing impurities.
For night time reading to put you to sleep, you can check this out: Galvanic corrosion - Wikipedia, the free encyclopedia
10-26-2011, 07:52 AM
#37
i wouldn't concerned with the flaking, it is doing its job. mine took 8 yrs to get down to abt 80%.
i wouldn't be concerned abt the pieces that wind up in the bottom, they are easily removed.
the metal isn't likely to make it into the hot water piping.
10-26-2011, 03:48 PM
#38
Arn
Umm, my understanding is that it needs to be replaced when it is 3/4 through to the steel core, not 3/4 gone from tip to tail. I'd be replacing that. $15 for an anode rod vs $$$$$ for a new water heater.
Arn
10-26-2011, 04:02 PM
#39
Arn, many campers replace the anode rod every year......not a problem.
The anode rod does not become any less effective as it wears down. Only when all of the anode is gone is there a problem.
Me, I would rather replace mine when necessary (maybe every 10 year ??), and put the $150 saved in my beer fund.
10-26-2011, 04:13 PM
#40
Arn
Interesting option. I like the way you think...
Arn
