Old 03-18-2013, 09:26 PM   #11
Jack of All Trades
RJHuser's Avatar
As said above, the anode rod is NPT which means National Pipe Thread, which is a tapered thread. If you look closely at the anode rod you will see that the plug diameter increases in diameter as you travel towards the head. NPT forms a seal by deforming the threads as you tighten the plug. The reason that either pipe dope or Teflon tape is needed is to assist in sealing the gaps between the threads.
When you put the anode rod back in, make sure the threads are clean on the rod and in the tank (use a wire brush to clean them), then use about three or four wraps of Teflon pipe tape or a thin layer of Teflon based pipe dope.
When you tighten the anode rod, don't over do it. Go finger tight plus one half turn. Fill the system and put it under pressure. If it leaks, tighten a quarter turn at a time untill it stops leaking.
One of the biggest mistakes people make with pipe threads is over tightening the joint.
Rick & Debbie; Brandy & Schnoodle (Dexter & Fritz R.I.P.) the Doxie "Kids"
2015 Jayco Pinnacle 36RSQS 5'er
2018 GMC Sierra Denali 3500HD, 6.6L Diesel Dually; B&W Companion 5'er hitch
ScanGauge, TST 507 TPMS
RJHuser is offline   Reply With Quote
Old 03-18-2013, 09:29 PM   #12
troyt's Avatar
I concur. I looks just like mine with a few threads sticking out.
2006 Dodge 2500 Crew Cab 5.9L Cummins 4X4 200k mls
2010 Forest River Flagstaff 831QBSS - Equal-i-zer Hitch
2011 HD FatboyLo & 2000 Honda Shadow 1100
Nights Camped 2010 (7), 2011 (15), 2012 (35) 2013 (40) 2014 (22) 2015 (12) 2016 (10) 2017 (?)
troyt is offline   Reply With Quote
Old 03-18-2013, 09:36 PM   #13
BillyBass's Avatar
when I winterize my hot water tank I took the anode rod out and run the hose thru it because it a had a lot of settlement in it then I think I put it back in was i suppose to that
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 03-18-2013, 09:38 PM   #14
OL Creeker's Avatar
Why didn't somebody tell me that last month?! About the pipe threads! Just because I didn't ask is no excuse.
Alan, Kathy & Cooper the camping cat
2014 Cedar Creek, 36CKTS
2013 GMC 2500 Denali
Duramax/Allison
Full timers since 5/30/2013
OL Creeker is offline   Reply With Quote
Old 03-18-2013, 09:58 PM   #15
3/4 NPT! Hows that. Youroo!!
Old 03-18-2013, 10:22 PM   #16
Mountainmanbob's Avatar
it is nice to put some Teflon tape on those threads
makes it easy to remove later
a while back my blow out plug was leaking on our RV heater
man oh man was that thing in there tight also
bent a wrench getting it out
Mountainman
Mountainmanbob is offline   Reply With Quote
Old 03-18-2013, 10:55 PM   #17
Happy owner SOB
I pulled mine the other day. Trailer is a 2012, put in service Sept of 12. The anode rod has SERIOUS erosion near the nut end of the unit. Normal?
sheriff1 is offline   Reply With Quote
Old 03-18-2013, 11:01 PM   #18
OL Creeker's Avatar
I soaked mine in vinegar to clean it, then gently, wire brushed it
Duramax/Allison
Old 03-19-2013, 07:46 AM   #19
KyDan's Avatar
Mine shows about half the threads when it's very tight.
Some will go in more than others.
That corrosion you see is because it's a sacrificial anode.
It's corroding 1st rather than your tank.
It's supposed to be slowly eaten away.
Once it's 3/4 eaten away you can replace it.
I know others here have various opinions about how often to replace it
but as long as there is 25% of it left, it's doing it's job.
See this thread post 2 for great photo's of the various stages of anode life.
Hot water heater anode
Peace!
Dan & Rita D
Blue Ox WD hitch
