Old 09-08-2016, 01:10 PM   #1
Water Heater assembly coming away from wall.
The water heater unit seems to be coming loose and working it's way off my Forester 3051S motorhome. I tried tightening a few screws which seemed to draw the unit back in partially, but the fix did not last.
BryonM is offline   Reply With Quote
Old 09-11-2016, 07:21 PM   #2
Problem solved. I replaced the three long mounting screws (#8, 3 1/2") with three larger (#10, 3 1/2") screws and the whole unit snugged up nicely. I also added a couple pieces of shim under the bottom edge of the unit to support it so it doesn't want to pull down and away.
I may look like I have it all together but deep down, inside my shoe, my sock is sliding off.
heater, water, water heater
