Originally Posted by porterwolf
Our 14' Grey Wolf has had a consistent problem with the water heater. Several times a weekend I find that we have no hot water. I go out and the pilot light is out, relight the darn thing and it usually lights fine. I found this week end that when I light the pilot and turn the knob, I hear the valve click, I can hear the gas, and wooof! The flame shoots out of the fire chamber and snuffs out the flame including the pilot light. Any ideas???
As for you water heater going off several times. there is some type of obstruction that is disrupting the fuel/air mixture. check all piping areas.
When you light the pilot light, leave the knob (with you holding it) in the same location (
'pilot lighting location) for a
few more seconds. That allows the end to
heat up and then the pilot will stay on when you
'slowly' turn the knob to the
on position. your pilot light should then stay on fine.
