Old 11-02-2017, 09:31 PM   #1
cardwellmarty's Avatar
Water heater burn smell
I am using my hot water heater with electricity only, tonight it smells like something burning, l can not pin point it, but its under the cabinet with water heater. I do not leave the water heater on all the time, but had it on most of the afternoon. There is no gas hooked up, i have unpluged it, but there are 3 wires going to the back of water heater i think goes to gas igniter but l am not sure, there is electricity there through the battery,the green /white goes to the fuse box on AC side, the white l think is ground, the yellow has current and l don't no where its feed from??? Click image for larger version
cardwellmarty is offline   Reply With Quote
Old 11-02-2017, 09:44 PM   #2
Fulltime family RVer
I can't help you identify the source as I called a mobile RV tech- but definitely make a point to find it. Hot burning smell = bad.
Here are wires from my water heater:
Old 11-02-2017, 09:52 PM   #3
Scoundrel
HangDiver's Avatar
Yikes!
2014 Micro Lite 19fd
2015 F-150 5.0L V8 XLT Crew Cab, 4x4, Tow Package, 36 gal tank, 3.55 locker, 1891 payload, Integrated Brake Controller
Wooden Spoon Survivor
HangDiver is offline   Reply With Quote
Old 11-02-2017, 10:04 PM   #4
You didn't say what model HWH you have. I've attached a service manual for the most common Suburban, and also a manual for an Atwood.
Both have wiring diagrams that may help you.
File Type: pdf Suburban Hot Water Heater Service Manual.pdf (3.55 MB, 82 views)
2011 Traverse LT, 3.6L, FWD
rockfordroo is online now   Reply With Quote
Old 11-02-2017, 10:07 PM   #5
Suburban, thank you
Old 11-02-2017, 10:09 PM   #6
I have all electricity off, AC or DC ,there are three wall plugd under the same cabinet but the smell isn't coming from them.
Old 11-02-2017, 11:05 PM   #7
Have AC and DC power off to water heater
Old 11-03-2017, 03:06 AM   #8
wmtire's Avatar
Your electric heating element runs ONLY off of 120 volt AC power. It will most likely have a power cord plugged into an outlet behind the water heater somewhere. This is one place to look for the cause of the burning smell.
Here is a pic that may help, that shows the 120 volt AC power cord just laying on the top of the tank. You can use it as a reference:
Another part that is bad about possibly burning is the electric element power switch on the face of the water heater. You have to pry it out of the housing to see if the lines/terminals on the backside of it are melted/burned. You can usually just stick a small flat-head screwdriver in at the top of the switch and push a tab down that lets you pull the switch out.
This is only a suggestion, and I'm not there to know exactly what/where it is that is burning, so I'm not at liberty to play with your safety. If you ascertain for sure it is something electrical with your water heater, you MAY (and I emphasize may) can just turn off the 120 volt AC circuit breaker to the water heater inside your RV's distribution panel...and still be able to camp until you can get it back home.
It will usually be a 15 amp circuit breaker like the one labeled below W/H
2011 Flagstaff 831 RLBSS
Just imagine, for a moment, if there were no hypothetical situations.
Old 11-03-2017, 07:34 PM   #9
Thurman's Avatar
I still get amazed at people who own a "hot" water heater
2015 FR Freedom Express 310BHDS pushing a 2014 GMC Sierra CC
Thurman is offline   Reply With Quote
Old 11-03-2017, 08:12 PM   #10
Well I took the water heater out where l could give it a good inspection, the wires going the heating element were melting, started where it's plugged in to the element, where it was burnt worse and was starting to melt the wire. The water heater is 10 years old, so l have a new one coming should be here mid-week, l am going to update the electrical plug also,has a cheap plug that just crimps the wire.
heater, water, water heater
