Old 11-05-2017, 06:30 PM   #1
Water heater bypass 2005 Forester 2901
Winterizing. Went to bypass the heater found only a cold shutoff valve. Shut it and pulled the anode. Tank drained and I did not replace anode. Blew lines out and pumped in pink stuff. None went into heater, but pink came out of the hot faucets. Iím assuming there is some sort of one way valve on the water heater hot out line, but couldnít find one. Thoughts?
2015 Forester 2901
2005 Scion XB
RacerRalph is offline   Reply With Quote
Old 11-05-2017, 07:34 PM   #2
Just as confused as you
Scrapper's Avatar
You are fine. You have a check valve at the outlet for your HW. There are almost as many bypass designs as there are floor designs.
This pic show the most common ones. You have #4 circled on the middle right.
Name:	Bypass Valves.jpg
Richard & Jill
Camping since 1989, seasonal since 2000
Old 11-06-2017, 06:49 AM   #3
Thanks Scrapper
2015 Forester 2901
2005 Scion XB
bypass, forester, heater, water, water heater
