Old 11-30-2009, 10:11 AM   #1
Water Heater Bypass?
I cannot locate the "bypass valve" on my waterheater in my 2009 Salem 266 FLSRV Toyhauler, am I that blind or is it possible it doesn't have one. And what do you do to send the antifreeze through everything if I in fact don't have one. Sorry but 1st year owner trying to winterize this thing myself. I also have access to compressed air so I could go that route if better/faster.
Thanks in advance
Scott
Scott is offline   Reply With Quote
Old 11-30-2009, 10:48 AM   #2
NWJeeper's Avatar
Hi Scott, welcome to the forum.
Go with the compressed air and don't worry about the bypass. Just pull the drain plug on the water heater to drain it. The antifreeze can be put down our sink drains if you wish to fill the P-traps but it is such a pain in the butt to flush from your lines when spring comes and you want to use your rig. I learned years ago when my dad used the antifreeze that it's just not worth the time and expense to use it. The compressed air is the way to go, just make sure to turn down your regulated air to 40psi. Nothing left in the pipes means nothing to freeze.
Ed & Wendy
www.nwjeepn.com
Old 11-30-2009, 05:40 PM   #3
milzat's Avatar
Scott, the standard features on the XL Toy Hauler include a water heater by-pass.
Comfort and Convenience
102" Exterior Width for Increased Living Space
84" Interior Height
Black Framed Tinted Glass Windows
WaterPur Whole House Water Filtration System
Water Heater By-Pass
6-Gallon Gas/Electric DSI Water Heater
Double Entry Doors (most floorplans)
Pass Thru Storage (per floorplan)
Dometic 13,5000 BTU Central Air Conditioner with Quick Cool Feature
In-Floor Ducted Heat with 30K BTU Furnace
Stain Resistant Carpet with Padding
Armstrong Tough Guard
Wood Flooring (Linoleum)
Flush-Floor Slide Rooms
System Monitor Panel
Jalousie Clamp Radius Windows (Bedroom, Living Room, and Kitchen)
Solid Oak Drawer Fronts with Wood Sides
Mortise and Tenon Cabinet Doors
milzat is offline   Reply With Quote
Old 11-30-2009, 05:48 PM   #4
Scott, most likely it is very near the back of your water heater. Look in a cabinet or pull out some drawers on the inside of your trailer in the area of the water heater. You may have to remove a panel that is hiding it. They don't make these things easy to find.
Hokiehall is offline   Reply With Quote
Old 11-30-2009, 06:10 PM   #5
milzat's Avatar
What Kim said.
From looking at photos of your model, the water heater in located below the sofa window. The by-pass should be on the inside in that general vicinity
Old 12-01-2009, 08:11 AM   #6
Thanks all
I will look afterwork and let you know the results, I did not check inside under the sofa so that will be the first place I look.
Scott
