03-23-2018, 09:44 AM
Water Heater Bypass Location
I'm trying to figure out where my water heater bypass is located. I have a 2011 Surveyor Sport SP-240. The water heater access is on the back side of the trailer. I've attached the floor plans in case that may help.
On a side note, does anyone have a digital copy of the owner's manual for this model? The Forest River website doesn't go back to 2011.
Thanks,
Amy
03-23-2018, 10:07 AM
Thanks,
Amy
It/they is/are at the water heater. Look for a removable panel. 1, 2, or 3 valves.
Mine is old school with one valve.
03-23-2018, 10:09 AM
Insert witty title here
Directly behind the water heater.
2021 Transcend Xplor 247BH
Husky WDH with Sway Control
2021 Chevy Silverado 2500HD LT 6.6L V8 Duramax
Forever in my memory. Forever in my heart.
Laurie J. Wood 3/22/67 - 8/23/19
I'm not familiar with your particular model, but unless you have one of those wet-bays with a bypass switch, most likely the bypass will be directly behind the water tank. You say it's on the back, is that the 'back' back? As in the rear of the camper? If so, based on the floor plan, it puts it either in that bathroom under your sink, or under the outside kitchen. Hopefully it's the bathroom, as that seems like it would be easier to get to. Look around under the sink for any kind of false panels that can be unscrewed and you'll hopefully find the bypass behind that.
03-23-2018, 10:11 AM
I would look under the bathroom sink if water heater is on back of trailer....
Fonzie
03-23-2018, 10:35 AM
Just as confused as you
While standing outside at the access panel to the WH, then using your mind's eye, picture what is inside the trailer at the same location. Go inside to that cabinet and open it up and look for a removable panel.
If the access panel is in the center of the rear wall, it will be under the bathroom sink.
If on the left rear side, look under the bath closet. If there a smaller access door at the bottom of the closet, it may have 3 hinges on it, 2 on one side, one on the other.
Richard & Jill
03-23-2018, 11:22 AM
Found It!
It is directly under the sink in the bathroom, behind what I did not even realize is an access panel!
Thanks everyone!
Amy
03-23-2018, 02:35 PM
Thanks,
Amy
Amy, FR usually doesn't produce a make/model specific owners manual for their travel trailers.
Instead they just kind of make a generic manual that covers operations of the appliances and other things that are most likely shared amongst all their trailers.
Can I ask if this is your first travel trailer? If so, I will provide you with a list of helpful posts that explains a lot of the functions of your trailer.
EDIT: BTW, welcome to Forest River Forums. Your username caught my attention as my daughter did a mythology school thing on her back in high school.
2011 Flagstaff 831 RLBSS
03-23-2018, 04:29 PM
Thanks for the info. This is our first, so any help would be appreciated!
Go Play Outside!
2011 Surveyor Sport
2017 Toyota Tundra
