Old 12-28-2018, 07:57 PM   #1
Water heater bypass valve
Hello All!
I have a 2018 forester 3011. I can not seem to find the heater bypass valve. I looked where the water filter is but the only valve I see there is the winterazation tube valve. Can someone please tell me where to look. A picture would be great also.
Thank you!
pranxsterr is offline   Reply With Quote
Old 12-28-2018, 07:59 PM   #2
Originally Posted by pranxsterr View Post
Hello All!
Thank you!
Look at the back of the water heater, that will be where you will find it.
2007 Surveyor SV230
- 200 Watts Solar/MPPT Controller - 230 AH Battery Bank - 600 watt PSW Inverter - (2) 2000 watt Inverter Generators - LED Lighting
2009 F150 - 5.4 Litre - Tow Package
Boon Docking 99% of the time.
boondocking is offline   Reply With Quote
Old 12-28-2018, 08:02 PM   #3
I opened the outside cover to access the water heater and I don’t see how to look behind it it totally enclosed with no access to the back
Old 12-28-2018, 08:05 PM   #4
There should be a removable panel at the back of the heater (inside the MH) to access the bypass valve(s).
2007 Surveyor SV230
Old 12-28-2018, 08:13 PM   #5
Looking here:
https://www.mhsrv.com/2018-forest-ri...-c-tx-i2057297
your water heater appears to be under the fridge. Looking at the inside pics, there's a panel under the fridge. You need to open/remove it. It may be screwed in place.
There are a number of ways they've plumbed the bypass valves. See here to see which you have:
2011 Traverse LT, 3.6L, FWD
Old 12-28-2018, 08:13 PM   #6
Thank you. I will check it out
Old 12-28-2018, 08:52 PM   #7
I just went out and found the panel you were talking about. It is located in a panel below the sink and not under the fridge. Thank you for your help!
Old 12-28-2018, 09:33 PM   #8
Just as confused as you
Scrapper's Avatar
Another poorly done PDI by a dealer. That is one of many things that should have been covered at the time of taking possession of any RV.
Richard & Jill
Camping since 1989, seasonal since 2000
Scrapper is online now   Reply With Quote
Old 12-28-2018, 09:40 PM   #9
You're right. I mis-calculated from outside to inside. Glad you found it.
Old 12-29-2018, 12:44 AM   #10
You are so correct. There is a ton of things the dealer did not go over with us. I had to find out most of the things on my own
bypass, heater, valve, water, water heater
