Originally Posted by Michael George Taylor
Hello,
Is it necessary to install a de-ionizer rod in the water heater of my 2007 Couger 5th wheel when using treated water?? I never had to use one in my 2004 Prowler Lynx 5th wheel. Are there different types of water heater liners that do not require a rod and some that do?
Thanks.
Mick Taylor
I think you are are referring to what is called a sacrificial anode rod.
If you have the Suburban brand water heater with it's steel tank, then yes you need to use an "anode" rod if you want it to last.
If you have an Atwood brand water heater with it's aluminum tank, then no, you don't use an anode rod.
