Old 04-03-2013, 08:31 PM   #11
Fulltime family RVer
Originally Posted by wmtire View Post
One more thing to keep in mind is that the electric water heater element does use a few amps to run (can average 9-13 amps). If you have a 30 amp RV, you have to be mindful of how many amps you are using as you are limited to basically 30 amps total.
If you start tripping breakers because of overload, just turn the water heater element off. You may need to when running microwaves, air-conditioning, etc.
With a baby and a bottle heater, we blew the breaker on a 30amp site in Florida a few times before I finally switched to propane (and left it) for the water heater.
ependydad is online now   Reply With Quote
Old 04-03-2013, 10:16 PM   #12
Graduate Member
RoadTrip's Avatar
Originally Posted by Mountainmanbob View Post
but
the propane is not an element
just a hot flame
Mountainman
ummm, can I claim typo?
--2009 Sunseeker 2860DS (Class C)
- one Hotwife, and two boys under 2(with one on the way!)
2013 - 53 days
2012 - 26 days
RoadTrip is offline   Reply With Quote
Old 04-04-2013, 06:42 AM   #13
Originally Posted by RoadTrip View Post
yep.
here's teh quick intro to hot water on an RV:
1) RV water heaters have two heating elements; electric and propane
2) elements can be used in any combo - elect/no prop; no elect/prop; both
3) propane heats quicker 20-30 min, elect slower at an hourish or more
4)ALWAYS ALWAYS ALWAYS turn on your water BEFORE turning on the electric element
5) electric elements burn out in 8 seconds if turned on with no water in the water heater
yep...that about covers it.
To add a little:
4A) Always open a hot water faucet and the water tank relief valve to be sure the tank is full of water. You can have water pressure but still have air trapped in the tank.
Old 04-04-2013, 06:50 AM   #14
TURBS's Avatar
yep.
1a) not All rv water heaters are both propane/electric. Some may be propane Only. No electric.
Turbs
Old 04-18-2013, 03:13 PM   #15
Dummy me!
hOW WELL I KNOW YOU NEED TO FILL THE WATER HEATER FIST BEFORE POWER. I DID NOT REALIZE I HAD IT IN BY-PASS MODE TURNED ON WATER HAD WATER RUNNING FROM BOTH HOT SIDE AND COLD BUT THE HOT WOULD NOT HEAT. YEAP, YOU GUESSED IT BURNED UP A HEATING ELEMENT REAL QUICK...
"LESSONS EARNED ARE LESSONS LEARNED"
chevy2500 is offline   Reply With Quote
Old 04-18-2013, 03:18 PM   #16
chevy2500, I almost did this. I got saved by a water leak and propane smell at the start of my last trip- so we had neither until the nearest RV dealer's owner came out to do some mobile RV repair for us. I knew to check for water and even tried the overflow/pressure release valve, just didn't know what I was doing. Fortunately, I hadn't turned it on before he found my winterization valves were still set to bypass the water heater. (I never would have guessed anything would come out of the hot side of the faucets like that - I thought they'd be empty. But, makes sense since you normally put antifreeze into them.) I got lucky.
Old 04-18-2013, 03:21 PM   #17
good for you. I will remember this time. Planning to de-winterize camper this weekend and head out for a fews days next week with the wife!
Old 04-18-2013, 03:23 PM   #18
dretired's Avatar
We use...electric at county & state parks koas.. its included with the dailey rate.. propane when snowbirding in Florida for 3 + months.. where.. WE.. pay a monthly electric meter rate.. and... camping world sells propane at $1.99 a gallon on tuesday and wednesdays
2014 Crusader 325 TE....2012.. F 250.. Supercab XLT, 4x2 , diesel....days camped 2011 ... 28.... days camped 2012...115 ... days camped 2013...155...2014...171 and counting
dretired is offline   Reply With Quote
Old 04-18-2013, 03:25 PM   #19
I posted a glowing review of them. He saved my tush on that, the water leak and helped me figure out the propane smell. I definitely got lucky.
There are a few things I definitely won't forget - 1) how to really know my HW tank is full; 2) to double and triple-check the winterization valves; 3) to properly winterize my toilets.
Old 04-18-2013, 03:33 PM   #20
Oaklevel's Avatar
Our current trailer is the first trailer we have owned that has a water heater that is both electric & propane..... I tend to leave it on gas just habit... It uses so little gas that I don't tend to think about it. If it were not for the furnace just using gas for the stove, grill, oven & water heater I usually only refill the tanks once a season.... Didn't think about the 30A service think I may just leave it on gas......
2005 Dodge 3500 Cummins
2017 Wildwood Lodge 4092 BFL
1966 Mustang GT
1986 Mustang SVO
Sadie & Lillie Spoiled Rotten Boxers
