Old 04-19-2013, 08:47 PM   #31
VinceU's Avatar
Originally Posted by f1100turbo
I have a 1000 gallon tank full on site.
Wow is that water or propane?
Old 05-03-2013, 07:50 AM   #32
rowdydog77's Avatar
First time with an RV that had both electric and propane as a heating choice..
So, if you have both electric and propane turned, what will the water heater use to warm the water. Electric or propane or use both at the same time?
2002 GMC Sierra C2500 HD 6.6L Duramax Diesel
2013 Sabre Silhouette 291BHTS
Pat, Michele and 2 old dogs, Shug & Sissy
rowdydog77 is offline   Reply With Quote
Old 05-03-2013, 07:57 AM   #33
TURBS's Avatar
Propane !
Old 05-03-2013, 07:58 AM   #34
TURBS's Avatar
Electric if your on shore power
Gas if your not on shore power
Both at the same time for quicker recovery when taking showers "while hooked to shore power" of course.
If both are turned on with shore power they will both work together.
Turbs
Old 05-03-2013, 08:34 AM   #35
wmtire's Avatar
Turbs
Expounding just a hair on Turbs great answer:
The propane side heats water quicker than the electric heating element side.
If you turned them both on at the same time initially, when all the water in the tank is cold, they both start heating the water. Once the water get's to it's hot temperature, the thermostat for the propane and the thermostat for the heating element will turn off each prospective side.
The electric heating element will now usually be all that is required to keep the water hot in the tank during standby times....so propane won't turn itself on.
However, once you start taking a shower, washing dishes or something else that requires hot water........as the temperature inside the hot water heater drops from hot water leaving and cold water entering to replace it...then the electric heating element will come on.
If the propane sides thermostat senses too much of a temperature drop, it will also turn the propane burner on too, in essence giving the system a faster boost to heat the water again. The propane side will stay on as long as required to heat the water again to it's set temperature till the thermostat senses it and turns it off again.
So if you have them both turned on, the system will use either one or both together as needed....according to each sides thermostats.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 05-03-2013, 08:51 AM   #36
Personally, if I'm on shore power, I don't want it to do that (in general). Electric is free. Propane isn't (even if it doesn't use much).
Old 05-03-2013, 08:54 AM   #37
B47
Not uncommon to see that large of a propane tank in rural areas. They are seen often around here in small ranches and buildings where they are no underground pipelines.
Old 05-03-2013, 09:07 AM   #38
wmtire's Avatar
Very true. However on 30 amp rigs, using the electric heating element (9-13 amps average) can limit you on other things. You usually can never run the air-conditioner, microwave, and electric heating element at the same time.
It's all just a tradeoff, and everyone has to decide for themselves what they want to save in propane costs vs expending energy to turn other AC powered things off when using the heating element.
I think everyone here who is experienced with 30 amp rigs, already know what they can and cannot use at the same time...and thus have adjusted their camping lifestyles to fit.
I use the electric heating element until it's my turn in our camping group to host the party/dinner. I then turn it off while we are cooking, browsing TV, playing cards, etc. to keep from tripping a breaker.
Once the party leaves, I turn the electric heating element back on. Works for my needs, but may not for anyone else's.
Old 05-03-2013, 09:30 AM   #39
Denver, CO
garbonz's Avatar
Wow, that's efficient! Imagine a home water heater drawing 90 amps? (10X larger) Maybe time to locate a close by supplier of propane who delivers......
The electric hot water heaters have a dedicated 220 volt 50 amp ( or 60) breaker. The size is determined by hot fast it needs to heater the water, which is always slower than the usage rate. That's why long showers always eventually run you out of water home or rv. It just happens faster in the RV cause of the long tank.
2017 Fuse 23T
Old 05-03-2013, 11:14 AM   #40
TURBS's Avatar
I posted last week .
Electric heating element for water heater and a/c running on high blower was drawing 22 amps, I belive which will go higher obviously on a hot humid day.
