I have a 2008 Surveyor and I am getting tired of having to remember to go outside and open the water heater door and find that tiny switch to turn on/off the electric water heater.
Anybody moved the water heater electric switch inside?
Wiring diagram?
Location of switch?
Type of switch? (I'd like lighted)
Wiring diagram?
Location of switch?
I did, and posted it here with some pictures. Quite easy to do. Do a search for it....
"I can fix it, and if I can't fix it, I can fix it so no one can fix it!" Ed & Wendy 2009 Georgetown 378TS | 1998 Jeep Wrangler | 1998 Skeeter ZX202C
Nights camped in 2009: 53 | Nights camped in 2010: 55 www.nwjeepn.com
Instead of moving the switch, we just leave the switch outside on, and flip the breaker on and off inside the unit when we want to use the electric water heater.
While this will work, circuit breakers aren't designed to be used as switches and therefore wear out with use. Also, if theirs is like ours, the power panel is as much a pain to get to as the outside switch is.
Gotta go campin!
i did it to on my fiver
i simply ran a switch up to the main panel where all the other on off things where
piece of pie so to speak
i posted it here as well
Living in the Piney Woods of Texas.
