Old 12-25-2019, 07:02 PM   #1
Water Heater Element
I have a 2015 FR Flagstaff 29fbss model.
I am trying to replace the water heater element and I can't not figure it out by the pictures the owners manual shows.
Can someone please tell me where I can change it at? My mother has no hot water and the propane burns too much to keep using it.
AmT-yd- is offline   Reply With Quote
Old 12-25-2019, 07:35 PM   #2
wmtire's Avatar
We have a tutorial in the FAQ subsection that shows how
Suburban water heater electric element R&R
I would test the element before removing it, as the problem could lie elsewhere (switch, thermostat, etc)
To test it, remove the cover as per the link above and also remove the electric wires. Now use a multimeter to check the resistance/ohms. It should be right at 10 Ohms for a good element.
You can check your new one to verify before checking the old one pre-removal..
2011 Flagstaff 831 RLBSS
Geaux Tigers!!!!
Old 12-25-2019, 07:43 PM   #3
Thank you!
Old 12-25-2019, 07:45 PM   #4
wmtire's Avatar
Can I ask where you got that element you have pictured showing in your hand. Is it a Suburban brand, and if not did you make sure to get a 120 volt one (not 240 volts).
The Suburban water heater element is of the 120 volt type, and not a 240 volt one like some home water heaters have.
BTW, the propane water heater doesn't just use a whole lot of propane, but the furnace sure does.
Geaux Tigers!!!!
Old 12-25-2019, 08:00 PM   #5
Minthillbill's Avatar
I don’t see an electric element in the picture of the water heater. The label indicates it is propane only.
2016 rockwood premier 2516G
2008 wildwood le 19BH
Tv 2018 F150 screw 3.5EB
Retired UNC Charlotte engineering professor.
Minthillbill is offline   Reply With Quote
Old 12-25-2019, 08:04 PM   #6
wmtire's Avatar
Uhhh, the label shows it as a Suburban SW6DE which the DE at the end means DSI & electric element.
http://www.rvcomfort.com/suburban/se...ater_model.php
Regardless, the pic shows the element cover. Propane only Suburban water heaters do not have the black plastic element cover at the bottom, as the one pictured below from the first post does behind the burner tube. It definitely came with an electric element.
Geaux Tigers!!!!
heater, water, water heater
