Old 11-27-2014, 08:05 PM   #1
Thekipkers's Avatar
Water heater falling short
Alright we have had our camper since May with multiple trips under our belt but I'm still learning.
Since going out we have had no issues with our suburban on demand water heater. The last two trips the hot water seems to fall short, it won't last an entire shower as it has before. My anode rod is showing the center core but thought that only has to do with the longevity of the unit.
What could be causing this lack of hot water. It lights up no problem and seems to run, but even leaving it on the entire day it still runs out before a single shower is over
Thekipkers is offline   Reply With Quote
Old 11-27-2014, 08:39 PM   #2
BillMFl's Avatar
I hate hater water. Try loving water instead. Open your pressure relief valve and let any captured air out.
BillMFl is offline   Reply With Quote
Old 11-27-2014, 08:40 PM   #3
TURBS's Avatar
Suburban has an on demand water heater?
I've not seen such a thing.
Model number?
TURBS.
Old 11-27-2014, 08:45 PM   #4
Thekipkers's Avatar
Sorry fat fingers and cold
Beverages makes it hard to focus..............
I may be misspoken on being on demand.
I open the pressure valve each time we hook up to ensure there's no air, and run each faucet to clear out any air in the lines.
Old 11-27-2014, 08:47 PM   #5
TURBS's Avatar
If it's the electric / propane model you can turn on both heating sources for quicker recovery.
Model number would help us identify what you have.
TURBS.
Old 11-27-2014, 08:49 PM   #6
Thekipkers's Avatar
No electric/ propane only, I'll check for a model number in a sec
Old 11-27-2014, 08:51 PM   #7
TURBS's Avatar
I believe sw6d is what you should have then.
TURBS.
Old 11-27-2014, 09:02 PM   #8
Thekipkers's Avatar
That is correct
Old 11-27-2014, 09:06 PM   #9
TURBS's Avatar
Yeah 6 gallons on propane only will be tough to keep good hot water when taking showers.
Unfortunately a sw6de would have been a better option.
Practicing HW conservation takes some time to get used to, especially with propane only fired water heater.
Unless the at temp switch is cutting out early there isn't much else to go wrong.
TURBS.
Old 11-27-2014, 09:14 PM   #10
wmtire's Avatar
Have you done anything with the bypass valve(s) behind the water heater, that is allowing cold water to mix in with the hot water line (this is very common). This will make the hot water seem to run out quicker.
Also, another culprit that can allow cold water to mix in with the hot water line, is when you leave the outdoor shower taps on, but cut it off at the shower wand head instead.......and forget about it. I would check this too, along with the bypass valve being completely shut behind the water heater.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
water, heater
