Old 10-20-2014, 07:24 PM   #1
water heater help
2015 XLR not sure how the Water Heater works. I have a switch on the outside where water heater is. Then one in the bathroom with a light. I'm guessing the one in the bathroom turns on propane and the one out side is for 120v. Any feed back would be helpful new at this so I'm learning.
Mickey Moto is offline   Reply With Quote
Old 10-20-2014, 07:29 PM   #2
Campin Cajun's Avatar
That sounds about right Mickey.
2013 Berkshire 390BH
Campin Cajun is offline   Reply With Quote
Old 10-20-2014, 08:02 PM   #3
wmtire's Avatar
Sounds like a Suburban brand. This detailed tutorial from the FAQ section may help:
Suburban's electric switch and much more
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 10-20-2014, 08:19 PM   #4
mark0224's Avatar
The switch outside is to turn on the electric hot water element, the switch on the inside is to use the gas part of the hot water heater. If you are camping where you have electricity I would use the electric element and save your propane, if you have no electricity use the propane. Make sure the tank is full of water before turning either on. Run water through the hot water valve furthest from the water pump until you get a steady stream the air should be all out of the tank then. If you don't get the air out the electric element will burn out and you will have to replace it. Once its full of water turn outside switch on and you will get hot water in about 15 min. If you have no electricity open the propane tank valve wait a few min. then hit that lighted switch inside and when the light goes out the heater should be lit. Make sure when you pack to go home you turn both switches off. I think I got it all the right way regarding the propane switch itself the rest I'm sure of.
Think about things before you do them make life easier not harder.
mark0224 is offline   Reply With Quote
water heater, water, heater
