Old 03-07-2015, 10:45 PM   #1
water heater help
My water heater makes a clicking sound but won't start what is the problem thanks for your help
gjcolmen54 is offline   Reply With Quote
Old 03-07-2015, 11:40 PM   #2
Additional information is needed in order to help. I assume you are talking about the LP side of your WH if you are talking about clicking... Is this a new rig or first time you are using it this year? It may take time for propane to fill your lines and reach the water heater. Does your stove ignite?
rana is offline   Reply With Quote
Old 03-07-2015, 11:45 PM   #3
TURBS's Avatar
if so equipped have you tried the electric side?
Old 03-08-2015, 01:02 AM   #4
wmtire's Avatar
If you have a Suburban brand water heater this may help:
Suburban's electric switch and much more
The first thing to always check, is to make sure you have propane and the cylinder valves are open/on.
If you have never used the propane option, or have air in the lines, your water heater may go into lockout mode. It's explained in the link above.
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 03-08-2015, 05:51 AM   #5
Did you make sure your main gas valve is open. X2
