Old 11-18-2013, 08:51 PM   #1
jlf
jlf's Avatar
Talking Water Heater how to's?
We just purchased a 2014 silverback 33 rl. We were rushed through the demonstration of how to operate the trailer. Thank goodness this isn't our first RV. But the water heater on the 33 rl works differently then prior ones. My hubby is having a hard time figuring out how to operate the water heater electrically and by gas. I told him I would ask this question and I know I will receive the correct answer. Thanking you in advance
jlf is offline   Reply With Quote
Old 11-18-2013, 09:08 PM   #2
BillyBass's Avatar
What brand is it.My has two switches one on the main panel and one back by the tank.the one by the tank is for elec.Being new its problemy electronic so the one the panel must be turn on.Can't answer anything else without knowing what your trouble is
2012 21' FR Micro Lite FBRS
2005 GMC Sierra 1500
2012 24 nites 2016 16 nites
2013 25 nites 2017 19 nites
2014 14 nites
2015 16 nites
BillyBass is offline   Reply With Quote
Old 11-18-2013, 09:37 PM   #3
wmtire's Avatar
If it's the common dual power source Suburban water heater, this FAQ may help:
http://www.forestriverforums.com/for...ore-36197.html
2011 Flagstaff 831 RLBSS
Iíve lost my scapegoat.
Old 11-19-2013, 01:37 PM   #4
BillyBass's Avatar
That is the way mind is set up.We need to know what the problem is so we can help you Jif bill
2014 14 nites
2015 16 nites
Old 11-19-2013, 02:57 PM   #5
TURBS's Avatar
If it is a suburban.
Gas switch should be inside at your distribution panel.
Electric switch is outside at the water heater inspection panel.
You can run gas only or electric only or both at the same time.
Be very sure water heater tank is full before turning either on.
You can check by opening pressure relief valve at the top of the heater on the outside.
Outside hiden switch.
Pressure relief valve.
Old 11-19-2013, 07:06 PM   #6
jlf
jlf's Avatar
Thank you for everyone's help. Finally spoke to hubby to find out what exactly the problem was. We do have the Suburban water heater. We were used to our other 5th wheel where the switches were side by side. You could tell when the heater was on because the light was red. So it was confusing to have one switch in one place and the other switch in another place. And no red light. So now with everyone's help, I think we have it figured it out. Thank you again for your help.
Old 11-19-2013, 08:14 PM   #7
BillyBass's Avatar
You Welcome
2014 14 nites
2015 16 nites
heater, water, water heater
