Old 04-21-2018, 05:39 PM   #1
Water heater ... I think it's dead, Jim
FR 394FKDS, parked at a campground in Central IL. Finally got the water turned on since it's above freezing. Fortunately I had the sense to get all of the water run thru the rest of the camper before undoing the water heater bypass. Crawled under the sink and thought "I don't remember the water heater being tilted last year".
We drained the entire system, including removing the plugs from the hot water line and making sure the water heater was totally empty. Should also have been no antifreeze in it. What would have caused it to pop and jump like that? It also broke the hold-down straps.
Thanks in advance!Click image for larger version
ID:	169128Click image for larger version
runmom1 is offline   Reply With Quote
Old 04-21-2018, 05:52 PM   #2
Thanks in advance!Attachment 169128Attachment 169129
Me thinks you didn't get it drained. From the rust I see it's time to replace it anyway.
Old 04-21-2018, 06:30 PM   #3
Yep, looks like it still had water in it and it froze and swelled up.
Decon Blue is offline   Reply With Quote
Old 04-21-2018, 06:32 PM   #4
Well, rats. Thanks for the confirmation. I swear we emptied it all the way ...
Old 04-21-2018, 06:33 PM   #5
when I drain mine I leave the plug out.
Old 04-23-2018, 04:46 AM   #6
DouglasReid's Avatar
Id put the plug back in if I were you. You don't want a mouse crawling in there and building a nest over the winter.
2009 Chevy Silverado 2500HD CCSB LTZ Diesel, Fumoto Oil Drain Valve, Turbo Brake activated, 39 gal Aux Tank W/ Fuel Pump transfer, Air Lift Loadlifter 5000 air bags.
DouglasReid is offline   Reply With Quote
Old 04-23-2018, 06:08 AM   #7
I remove the outside vent cover and line with tin foil. No bug access. Same for the fridge vent cover.
Old 04-23-2018, 06:21 AM   #8
Since this is a "Estate Type Unit" I would venture to say that it has a Valve not a Plug for draining the Tank! The valve they use is a Cheap screwdriver slot type that is very easy to Clog with Crap,thus Not Draining all the Way! Youroo!!
Old 04-23-2018, 06:26 AM   #9
Herk7769's Avatar
Originally Posted by youroo View Post
Since this is a "Estate Type Unit" i would venture to say that it has a Valve not a Plug for draining the Tank! The valve they use is a Cheap screwdriver slot type that is very easy to Clog with Crap,thus Not Draining all the Way! Youroo!!
Sounds like a winner.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
heater, water, water heater
