02-24-2012, 06:02 PM
Water heater not getting hot enough
We have a 2003 Georgetown with a 6 gallon suburban water heater.
The problem is it doesn't get hot enough, even turned all the way hot my wife can wash her face with it. I try to take a very short shower (turning it off and only spraying me when necessary) and quite often run out of hot water. It does seem to get a bit hotter on gas than electric.
Does anyone out there had a similar experience of idea of what can be done about this
02-24-2012, 06:11 PM
sounds like you have a bypass turned on due to the fact you say it happens on gas or electric and not sure where your bypass would be
2011 Rockwood Mini Lite 2306 - Matt
2004 Dodge Ram 1500 Qaud Cab 4x4 with 35" tires and 3.92 gears, Dynatech Longtube Headers & Fabtech 6" lift + Superchips with shift Tuning
Nights Camped 2011 (37) - 2012 (16)-2013 (2) -2014 (5) -2015(0)
USMC 91 - 95 - F/A-18 Aviation Ordnance
02-24-2012, 06:49 PM
CLASS "A" Senior Member
sherdep's post sounds to be the answer. What model number do you have? Hopefully someone with the same model can give you the exact location of the by-pass valve. In my case the by-pass valve is behind a 4" screw in access cap. It's in my propane compartment on the left. I have to reach in to near the back of the water heater to turn the valve.
2007 Georgetown 370TS
aka - RAYNMKR
Driver: Charlie
Navigator: Sheri
02-24-2012, 06:54 PM
Normally its directly behind the hw heater.
Sounds like the issue to me to
02-25-2012, 07:16 PM
bypass valve?
Are you talking about the water bypass ??
If not I don't know what a bypass valve is or where it is located.
The model of our suburban water heater is SW6 DE
Please more help required
02-25-2012, 07:24 PM
you should have a water heater bypass. should be right next to the WH.
it's so that when you winterize, you don't get a bunch of antifreeze in the water heater.
you don't want antifreeze in your FW tank nor your WH.
02-25-2012, 07:28 PM
You'll have a line that ties the hot water line from your hot water tank to the cold water line running into the tank. On this line there should be a valve. It needs to be in the off position. That would be cross ways with the line. It sounds like the valve is open allowing the cold water to mix with the hot.
All this should be located at the back of your hot water tank. I am not familiar with your coach so I can't help you with it's location.
Hope this helps.
I just wanted to add, there will be valves on the hot & cold water lines. These seem to be in the correct position since you're getting water throughout the coach. The only valve you should turn at this point is on a line that connects the hot and cold lines.
04-01-2012, 10:01 AM
will my water heater not work in my freedom express 310bdhs if im not level
04-01-2012, 10:04 AM
Yep, bypass valve open.
It should be closed (90 degrees to pipe) when in use.
Lou & Freya the wonder dog
2019 Flagstaff 8529FL
04-01-2012, 10:06 AM
Your hot water heater should work, even off level. The RV Fridge may not work if the unit is way out of level.
Do you have an issue with the water heater?
Bill M
2012 Georgetown XL 360
2011 Chevy Equinox - 2006 Chevy Avalanche
04-01-2012, 10:09 AM
What?
04-01-2012, 10:14 AM
I had the same problem this year, forgot to close the bypass valve. Only lukewarm if the valve is open.
2011 Ram Truck 2500, Crew Cab, 6.7L CTD, 4X4, 3.73 Rear
04-01-2012, 11:56 AM
Director, FROG
We just had two units on the Cherry Blossom Festival trip with the same "warm but not hot" water issue. The solution in both cases was to close the bypass valve.
Herk, great job. 1 picture = 1000 words.
04-01-2012, 04:35 PM
why is my water heater humming on electric side only
04-01-2012, 05:12 PM
Its happy?
Sorry, don't know the answer.
Scott
DW, 3 Kids and our Goldens
2012 Shamrock 233S
2008 Toyota Sequoia 5.7L 4WD
04-01-2012, 05:48 PM
Originally Posted by herk7769
What?
double WHAT?
04-01-2012, 05:51 PM
Could it be that the electric element is giving up the ghost...is there water in the tank.
Bill M
04-03-2012, 09:22 AM
I re-read your post again and I realized that this is a question; not a statement.
The water heater will work in electric and gas modes fine unless the camper is on its roof. In that case, it will only work in electric.
04-07-2012, 01:04 PM
I just had the same issue I was dewinterizing my Solera for the first time getting ready for a 2 week trip and missed one valve. On the Solera you have to stick your head well under the bed to see that third valve. Too many months since I winterized so I had forgotten. Now I have scalding hot water. Thanks to this forum I found the solution.
04-09-2012, 12:54 PM
Originally Posted by Triguy
Its happy?
LOL. You guys are killing me today!!!
2012 Rockwood 8293RKSS
