Old 05-24-2014, 10:06 AM   #1
Bilcin's Avatar
Water heater not keeping water hot
My 6 gallon water heater does not keep the water hot. the pilot is working, when I increase the temperature on the thermostat it fires up and heats up the water. After that it will not fire up again. Could it be a faulty thermostat?
Sent from my LGMS323 using Forest River Forums mobile app
Bill & Cindy McKenna
Philadelphia PA
2015 Palomino Puma 32DBKS
2005 Ford Excursion 6 liter Turbo Diesel
Bilcin is offline   Reply With Quote
Old 05-24-2014, 10:14 AM   #2
VinceU's Avatar
Very possible, call suburban with a choice of fixed temp settings. About 25 dollars.
Old 05-24-2014, 10:33 AM   #3
Bilcin's Avatar
Thanks, my thermostat settings are warm, hot and hotter and it is a upside down triangular piece of plastic with holes in it where a pin goes in the hole for each temperature setting.
Philadelphia PA
Old 05-24-2014, 11:05 AM   #4
VinceU's Avatar
Wow had them with pilot never with set a temp! Before my time LOL!
Old 05-24-2014, 04:09 PM   #5
Iggy's Avatar
Do you have your winterized bypass valve open?
It is the valve between the cold water in and the hot out.
This can make the water cooler.
Here is a basic picture of what you should be seeing.
If the handle is in line with the hole it is open.
If the handle is cross the line it is closed.
Your valves should be like the top picture for normal use.
Old 05-24-2014, 04:43 PM   #6
Cypressloser's Avatar
Location: Alberta - East of the Rockies, West of the Rest
If you have an outside shower make sure both hot and cold tabs are closed otherwise hot and cold water are being mixed.
Almighty 2018 RAM 5500 Laramie CC
Riverstone Legacy 38RE, 960 Watt Solar, 6x6 Volt Battery Bank, Freedom SW 3012 Inv/Charger
Cypressloser is offline   Reply With Quote
Old 05-26-2014, 09:30 PM   #7
Bilcin's Avatar
Talking
Ahaaaaa, you solved my problem. I have been shutting the valve when I winterized it and opened the valve when I opened up my trailer.
The wife will be happy! Thanks
Philadelphia PA
heater, water, water heater
