Old 07-10-2012, 08:05 AM   #1
MaD
Water heater not working on AC (SOLVED)
My water heater only seems to be working on propane.
There is a switch outside in the WH area it had a pin in it to keep it Off. I turned on the switch on the inside of the trailer next the to the propane switch. Left it on over night still no hot water. I also tried with both switches on and still no luck. I checked the breakers everything is ok.
Is there something else i'm missing?
MaD is offline   Reply With Quote
Old 07-10-2012, 08:10 AM   #2
TURBS's Avatar
Did you check the reset breakers on hw heater?
Was it full of water when you turned on electric and or propane switches?
Old 07-10-2012, 08:23 AM   #3
MaD
Yes, i reset the breaker just to make sure, tested the pressure valve to make sure there was water in it. Worked in a short time with the propane.
Old 07-10-2012, 08:32 AM   #4
TURBS's Avatar
Take heater element cover off and turn on electric side of heater.
Make sure water is cold.
Check across both terminals at element. You should have no less than 110v.
Old 07-10-2012, 08:39 AM   #5
Herk7769's Avatar
The AC side of the water heater is independent of the propane side. It is the simplest to troubleshoot as well.
The two limit switches are located under the rubber reset covers. Press both (through the rubber cover!) and try the AC again.
If that does not work remove the two screws holding the rubber cover on and check for AC voltage. If you have voltage on one of the terminals of the AC limit switch but not on the other after you reset it, the limit switch is bad.
Note the one on the left (AC in this photo) has "opened" and the one on the right (DC) is "OK".
If you have AC voltage on both terminals and still no hot water, the heating element is bad.
Name:	AC diagram.jpg
ID:	16316   Click image for larger version
Name:	Limit Switch Reset.jpg
ID:	16317   Click image for larger version
Name:	Hot Water Heater.jpg
ID:	16318   Click image for larger version
Name:	Rocker Switch.jpg
HAM CALLSIGN - KC3FFW
Old 07-10-2012, 09:25 AM   #6
MaD
Thanks a lot. I will try that out tonight.
Old 07-11-2012, 11:58 AM   #7
MaD
Found the issue, there were wires behind the water heater not hooked up properly. Easy fix.
Thanks for all your help.
Old 08-05-2012, 08:30 PM   #8
Does both switches have to be in the on position to use electricity?
vduke is offline   Reply With Quote
Old 08-05-2012, 08:37 PM   #9
MaD
Mine had a pin through the switch in the outside compartment. This means the switch is a dummy switch. It was in off position with a pin through it.
Old 08-05-2012, 08:56 PM   #10
bob213's Avatar
That's not always true. Most Suburban WHs are shipped with the pin thru the switch to keep them from being turned on accidentally without water in the tank. Alot of Suburban WHs do not have an AC switch on the inside of the trailer..only a propane switch. Then you have to go outside and turn on that toggle switch to get it to run on electric.
bob213 is offline   Reply With Quote
