Old 08-29-2012, 07:17 AM   #1
ns-sabre
ns-sabre's Avatar
Water heater not working (SOLVED)
Searched on water heater and saw this forum . We are about 4 hrs from dealer and about to head out on week trip to Maine and water heater has started to act up. We generally use electric, which has stopped working. I have reset breaker etc without luck. Used propane one day and then it stopped. I thought maybe because it was a very windy day. We travelled one day and the propane came on last night, however this am propane is not working ( stove etc has propane) any ideas or suggestions?
Any ideas on water heater appreciated.
ns-sabre is offline   Reply With Quote
Old 08-29-2012, 07:26 AM   #2
Herk7769's Avatar
The Propane and VAC parts of the water heater are TWO completely different systems). The only common denominator is the water in the boiler itself.
So, I would be looking at the water over heating and opening the high limit switches on each thermostat.
Remove the outside cover over the water heater and push in on the two rubber circles and see if the limit switch bellows reset. If they are "set" you might need to remove the rubber cover and examine the thermostats themselves for damage (like the burned out fusible link in the left (VAC) thermostat).
Name:	AC diagram.jpg
ID:	18829   Click image for larger version
ID:	18830   Click image for larger version
ID:	18831   Click image for larger version
Name:	Limit Switch Reset.jpg
HAM CALLSIGN - KC3FFW
Old 08-29-2012, 09:19 AM   #3
ns-sabre
ns-sabre's Avatar
Thank you Herk very much for quick reply. I checked as per your instructions, reset seemed ( see attached). Still no electric. On the propane it was sparking but not lite. Si I decided to open second lp tank, and it fired up. I usually only keep one tank open, so when it goes red I know to switch and fill. Wondering even thought indicator was green if first tank is getting low so as ok flow to stove, but not water heater? Won't be surprising as have been running on that lp tank for a while. Test a few more times before conclusive, can live with lp heater until fall dealer visit.
Old 08-29-2012, 10:02 AM   #4
ns-sabre
ns-sabre's Avatar
Sorry, forgot pic
ID:	18838   Click image for larger version
Old 08-31-2012, 11:14 AM   #5
ns-sabre
ns-sabre's Avatar
As a update the propane continues to generally work, generally as once or twice the dsi lite has come on and I had to rest switch. Maybe this is common on propane side as I have typically used electric. In regards to opening second tank i recall I had to do this in cold weather in the spring for heater. Heater actually would not work one time when one tank was empty.a little troublesome as its means always having to keep both tanks fairly full to insure heat or hot water. Will have dealer check regulator in fall service.
As for the electric have checked best i can, including meter at element( no ac , but breaker is not tripped). Will run on propane until i get to dealer. Thanks again Herk.
Old 08-31-2012, 11:29 AM   #6
Herk7769's Avatar
If the buttons do not "set" when you push them in then they are most likely "OK" and you VAC heater element is most likely burned out and needs replacing.
Old 01-28-2013, 10:29 AM   #7
tom50mg's Avatar
I am having a problem as well,only on the vac side,I checked for current at the recepticle in the trailer,it,s o.k,current going through the left side of hi temp thermostat,but no current at element,there is a module on top of the water heater with looks like printed circuits in it,stuck for an answer here!
tom50mg is offline   Reply With Quote
Old 01-28-2013, 10:59 AM   #8
Dave_Monica's Avatar
Has the water heater ever been on AC power with no water in it...it will fry the element in a few seconds. It's not expensive or hard to change out.
Dave
Old 01-28-2013, 11:05 AM   #9
TURBS's Avatar
To check a bad element
You can disconnect the two wires going to the heating element and use an ohm meter "one probe to each screw" to check if element is "open"
If it is open element is trash can material.
Turbs
Old 01-28-2013, 11:25 AM   #10
tom50mg's Avatar
I checked the element registers 10.6 ohms,I think between 10 and 16 ohms it is o.k,been on the road for 2 weeks now with out any problems until this morning,It works on gas fine though!
